Trouble validating EBRSM model - fvOptions problem ? |
March 30, 2022, 10:03 |
Kermit
Rep Power: 5 |
Hello everyone,
I just implemented the EB model of Manceau, R., & Hanjalić, K. (2002) following the lines of Javadi, A. (2016). However, I'm having trouble to validate my implementation with the channel flow at Retau=395... I attached my results with the precursor simulation (left) and the simulation with EB model (right). kOmegaSST_results.jpg EBRSM_results.jpg Note that the u+-profile is good wtih the precursor simulation (not with the EB model) and that the flow accelerate in the centerline with the new turbulence model. This is confirmed when we look at the pressure gradient in the log of both simulations: 0.985 for the precursor simulation and 0.689 with the other. Does anyone faced those kind of issue ? Does anybody knows how to solve this ? Thanks. NB: I'm using OpenFOAM v2012. |
March 30, 2022, 10:58 |
Herpes Free Engineer
Rep Power: 12 |
Good to double check your implementation: discrepancy in fvc::grad(U)
Did the EBRSM converge? Did you run the simulation long enough?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
March 31, 2022, 13:41 |
#3 | |
Kermit
Rep Power: 5 |
Since yesterday: 1) I've double checked my implementation as you suggested. 2) I've compared my implementation with SSG model because the part where gradU is used is the same as in EB model. To me, all seems good! Still attached my model and the test case: validation_ebrsm.zip And yes, the results that I show are converged... Do you have any other ideas ? Thanks a lot for the help! Last edited by tyskies; March 31, 2022 at 15:03. |
March 31, 2022, 15:22 |
Rep Power: 12 |
- uncomment "correctNut()" func.
- run the case with "simpleFoam" with "consistent=true" May be the following is equivalent to what you have, but the new is less confusing to me - volTensorField Omega(skew(gradU)); => volTensorField Omega(gradU.T() - gradU); // remember OpenFOAM's gradU is actually the tranpose of the usual Jacobian notation - twoSymm(b & Omega) => twoSymm(b & Omega.T()) hope these help
March 31, 2022, 16:40 |
#5 | |
Kermit
Rep Power: 5 |
Thanks for your answer ! I've modified the code the way you suggested and re-run the case with pisoFoam and simpleFoam. Unfortunately (or not!), I get the same results with both solvers: pisoFoam_EBRSM_results.jpg simpleFoam_EBRSM_results.jpg EDIT: The horizontal axis of the top right corner figure is y+, not (x2/delta). I think the problem is due to the way the solver adjusts the pressure gradient because it drops quickly at the beginning of the simulation... Have you ever read a thread on those kind of issues with the meanVelocityForce option ? Another time thanks for your help! |
April 1, 2022, 03:53 |
Rep Power: 12 |
I am confident that "meanVelocityForce" is fine.
How many iterations did you run in simpleFoam case?
April 1, 2022, 04:09 |
#7 | |
Kermit
Rep Power: 5 |
Yes, actually I agree with you on meanVelocityForce (thinking of it during the night!). I ran 100 000 iterations. It looks like the Reynolds stresses and the U+-profile converged at the 25 000th iteration. Moreover, the pressure gradient/wall shear stress is 0.7185 at the end of the simulation whereas it should be around 0.98. Last edited by tyskies; April 1, 2022 at 04:13. Reason: Add information to my reply! |
April 5, 2022, 07:31 |
#8 | |
Kermit
Rep Power: 5 |
I've done some tests and when I remove the boundary condition on epsilon I get the same results. Everything is working as if the boundary condition on epsilon isn't applied. As my programming skills in OpenFoam are limited, have you any idea how I can improve this part ? Moreover, what does the following command epsEqn.ref().boundaryManipulate ? Thanks for your help! Last edited by tyskies; April 5, 2022 at 12:43. |
April 6, 2022, 10:24 |
#9 | |
Kermit
Rep Power: 5 |
const fvPatchList& patches = this->mesh_.boundary(); forAll(patches, patchi) { const fvPatch& curPatch = patches[patchi]; if (isA<wallFvPatch>(curPatch)) { //const scalarField& nuw = nu().boundaryField()[patchi]; forAll(curPatch, facei) { label celli = curPatch.faceCells()[facei]; epsilon_[celli] = 2.0 * 0.002532 * k_[celli] / 0.0003 / 0.0003 ; // / (nearWallDist(this->mesh_).y()[facei] * nearWallDist(this->mesh_).y()[facei]); // this->y_[patchi][facei] / this->y_[patchi][facei]; } } } Now, I need to properly implement the following boundary condition: epsilon = 2 * nu * k_ / y / y However, when I use the following lines: Code:
const fvPatchList& patches = this->mesh_.boundary(); forAll(patches, patchi) { const fvPatch& curPatch = patches[patchi]; if (isA<wallFvPatch>(curPatch)) { forAll(curPatch, facei) { label celli = curPatch.faceCells()[facei]; // epsilon_[celli] = (1/0.0003/0.0003) * nuw[facei] * k_[celli] ; // / (nearWallDist(this->mesh_).y()[facei] * nearWallDist(this->mesh_).y()[facei]); // this->y_[patchi][facei] / this->y_[patchi][facei]; epsilon_[celli] = 2.0 * nu_[celli] * k_[celli] / curPatch[facei].y() / curPatch[facei].y(); } } } Code:
error: no match for ‘operator[]’ (operand types are ‘const Foam::fvPatch’ and ‘Foam::label’ {aka ‘int’}) 412 | epsilon_[celli] = 2.0 * nu_[celli] * k_[celli] / curPatch[facei].y() / curPatch[facei].y(); Thanks for your help! Last edited by tyskies; April 6, 2022 at 11:59. |
Air-lift model with hot gases and water. Time step problem. | PauliusRap | FLOW-3D | 0 | August 4, 2014 04:47 |
Mixture model problem - could someone please advise? | matlab_monkey | FLUENT | 2 | July 26, 2012 08:20 |
Turbulence model for mixing problem??? | nileshjrane | Main CFD Forum | 7 | September 14, 2010 04:57 |
Turbulence model for mixing problem | nileshjrane | OpenFOAM Running, Solving & CFD | 1 | September 7, 2010 17:48 |
problem with MFR model for multiphase mixing tanks | Srinivas | Main CFD Forum | 1 | November 7, 2005 14:16 |
