groovyBC Error
Old   April 18, 2022, 13:18
Default groovyBC Error
Vahid
Kavi is on a distinguished road
Hello everyone,
I am trying to set up a case to simulate water current interaction and a solid disk. also, I am using SHM and extrudeMesh to mesh the model, simpleFoam or PimpleFoam as the solver.
As the inlet velocity boundary condition, I want to implement a parabolic velocity profile, then I have used groovyBC as follows:
inlet
    type              groovyBC;
    value             $internalField;
    valueExpression   "1*para";
    variables         "yp=pts().x;minY=min(yp);maxY=max(yp);para=-1.5*(maxY-pos().y)*(pos().y-minY)/(0.25*pow(maxY-minY,2))*normal();";
but, I got the error:
--> FOAM FATAL ERROR: (openfoam-2106 patch=211215)
The expected return type scalar is different from the stored result type "vector"
also, when I removed the term *normal() I got the:
The expected return type vector is different from the stored result type "scalar"
Does anyone know how can I get rid of this error?
Thanks in advance.
Kavi is offline   Reply With Quote
groovybc, parabolic velocity
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
