How to get convergence with simpleFoam?
5 Attachment(s)
Hello Everyone,
I am trying to learn openFoam by simulating a flow inside a rectangular chamber (wall-blue) with inlet (green) and outlet (red)(see figures). I use inlet velocity of (1 0 0) and fixedValue (0 0 0) as outlet condition for Pressure. I created the geometry in salome and castellated mesh was created using snappyHexMesh. I ran the simulation till 2000 and even 6000 and I was not getting a convergent solution. I checked the mesh using checkMesh and the output was OK. I have attached the screenshot of the calculated value of velocity at time step 1802 and 1902. Below I have pasted the boundary condition of velocity and Pressure. I have also pasted the controDict, fvSolution and fvSchemes that I have used. For this case what should be the steps to be followed to get a convergent solution? Thank you for your support in advance :). -------- Velocity Boundary File ---------------- internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (1 0 0); } outlet { type zeroGradient; value uniform (0 0 0); } wall { type noSlip; value uniform (0 0 0); } } --------------- Pressure Boundary File ------------ internalField uniform 0; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } wall { type zeroGradient; } } -------------- controlDict ----------------- // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom startTime; startTime 1; stopAt endTime; endTime 6000; deltaT 1; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; ---------- fvSchemes ---------------- ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } ------------ fvSolution -------------- solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; nCorrectors 3; consistent yes; residualControl { p 1e-2; U 1e-3; } } relaxationFactors { fields { p 1; } equations { U 0.9; // 0.9 is more stable but 0.95 more convergent } } ---------- |
