May 25, 2022, 12:02 |
SRFPimpleFoam
Christoph
Rep Power: 5 |
Hello everybody,
I am currently trying to do a transient simulation of a wind turbine rotor blade in a single reference frame (SRF) using SRFPimpleFoam (OF-v2112 and v1912). Before, i already managed to get a steady-state solution using SRFSimpleFoam. However, as i start SRFPimpleFoam, the values for the pressure go through the roof immediately (the solver keeps running though, but produces an unphysical solution). I have all the same Mesh and BC as in the steady case, so i really dont understand why these problems occur at all. Maybe someone has an idea why this is the case. I will provide more details about my case below. General Setup: - 120°-domain in a SRF (see. Fig.1) - cyclicAMI on rotational symmetry planes (side_left, side_right) - initialized with the results obtained with SRFSimpleFoam - Turbulence Model: SSTLM The Problem: - extremely high pressure, already after first iteration SRFSimpleFoam gives values for pressure between -5e3 and 2e3, after the first time step of SRFPimpleFoam i get values between +-2e8. -> see Fig.2 - rest of the fields does not seem to be affected - seems like the cyclicAMI patches could be the problem? Things i changed compared to steady case: - controlDict: Code:
application SRFPimpleFoam; startFrom latestTime; deltaT 1e-8; - fvSolution: I also have tried having more OuterCorrectors and control the loop with residualControl. Code:
PIMPLE { momentumPredictor yes; nNonOrthogonalCorrectors 2; nOuterCorrectors 3; nCorrectors 3; consistent yes; pRefCell 0; pRefValue 0; turbOnFinalIterOnly false; correctPhi true; ... } The log-file for the first iteration: HTML Code:
Create time Create mesh for time = 0 PIMPLE: max iterations = 3 field p : relTol 0, tolerance 0.0001 field Urel : relTol 0, tolerance 1e-06 field "(k|omega|ReThetat|gammaInt)" : relTol 0, tolerance 1e-06 Reading field p Reading field Urel Reading/calculating face flux field phi AMI: Creating addressing and weights between 59136 source faces and 55552 target faces AMI: Patch source sum(weights) min:0.999999 max:1 average:1 AMI: Patch target sum(weights) min:0.999986 max:1 average:1 Creating SRF model Selecting SRFModel rpm Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSSTLM Selecting patchDistMethod meshWave bounding k, min: 0 max: 946.983 average: 2.30207 Employing decay control with kInf:kInf [0 2 -2 0 0 0 0] 6.5e-05 and omegaInf:omegaInf [0 0 -1 0 0 0 0] 16.36 kOmegaSSTLMCoeffs { a1 0.28; b1 1; c1 10; F3 no; ca1 2; ca2 0.06; ce1 1; ce2 50; cThetat 0.03; sigmaThetat 2; lambdaErr 1e-06; maxLambdaIter 60; decayControl yes; kInf 6.5e-05; omegaInf 16.36; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; } No finite volume options present Starting time loop forces forces: rho: rhoInf Freestream density (rhoInf) set to 1.225 Not including porosity effects Courant Number mean: 1.75657e-06 max: 0.20131 Time = 1e-08 PIMPLE: iteration 1 DILUPBiCGStab: Solving for Urelx, Initial residual = 3.61499e-11, Final residual = 5.13285e-33, No Iterations 4 DILUPBiCGStab: Solving for Urely, Initial residual = 4.49548e-10, Final residual = 1.59125e-31, No Iterations 4 DILUPBiCGStab: Solving for Urelz, Initial residual = 5.0328e-11, Final residual = 6.55993e-33, No Iterations 4 GAMG: Solving for p, Initial residual = 0.999989, Final residual = 0.0082096, No Iterations 12 GAMG: Solving for p, Initial residual = 0.0204345, Final residual = 0.000194422, No Iterations 61 GAMG: Solving for p, Initial residual = 0.00678058, Final residual = 6.68389e-05, No Iterations 61 time step continuity errors : sum local = 5.92363e-15, global = 4.22576e-16, cumulative = 4.22576e-16 GAMG: Solving for p, Initial residual = 0.00239474, Final residual = 2.34477e-05, No Iterations 79 GAMG: Solving for p, Initial residual = 0.00106585, Final residual = 1.0611e-05, No Iterations 89 GAMG: Solving for p, Initial residual = 0.000464535, Final residual = 4.64077e-06, No Iterations 155 time step continuity errors : sum local = 4.1481e-16, global = -8.04959e-19, cumulative = 4.21771e-16 GAMG: Solving for p, Initial residual = 0.000224096, Final residual = 2.31606e-06, No Iterations 300 GAMG: Solving for p, Initial residual = 0.000105327, Final residual = 1.4517e-06, No Iterations 300 DICPCG: Solving for p, Initial residual = 5.24223e-05, Final residual = 9.96327e-07, No Iterations 136 time step continuity errors : sum local = 8.91004e-17, global = 3.39321e-18, cumulative = 4.25164e-16 DILUPBiCGStab: Solving for omega, Initial residual = 1.42567e-15, Final residual = 3.97108e-30, No Iterations 3 DILUPBiCGStab: Solving for k, Initial residual = 1.12692e-11, Final residual = 1.63946e-27, No Iterations 3 bounding k, min: -1.75187e-10 max: 946.84 average: 2.30206 DILUPBiCGStab: Solving for ReThetat, Initial residual = 2.3811e-09, Final residual = 5.1669e-28, No Iterations 3 DILUPBiCGStab: Solving for gammaInt, Initial residual = 3.48693e-10, Final residual = 4.30537e-31, No Iterations 3 PIMPLE: iteration 2 DILUPBiCGStab: Solving for Urelx, Initial residual = 4.25948e-06, Final residual = 1.35464e-31, No Iterations 4 DILUPBiCGStab: Solving for Urely, Initial residual = 3.87176e-05, Final residual = 7.55888e-30, No Iterations 4 DILUPBiCGStab: Solving for Urelz, Initial residual = 4.06583e-06, Final residual = 1.66793e-31, No Iterations 4 GAMG: Solving for p, Initial residual = 0.224347, Final residual = 0.00203955, No Iterations 7 GAMG: Solving for p, Initial residual = 0.0155198, Final residual = 0.000149521, No Iterations 75 GAMG: Solving for p, Initial residual = 0.00587188, Final residual = 5.64349e-05, No Iterations 53 time step continuity errors : sum local = 3.79089e-15, global = -2.83492e-16, cumulative = 1.41672e-16 GAMG: Solving for p, Initial residual = 0.0024005, Final residual = 2.334e-05, No Iterations 65 GAMG: Solving for p, Initial residual = 0.0010719, Final residual = 1.04598e-05, No Iterations 67 GAMG: Solving for p, Initial residual = 0.000496189, Final residual = 4.94625e-06, No Iterations 89 time step continuity errors : sum local = 3.30134e-16, global = -1.57436e-17, cumulative = 1.25929e-16 GAMG: Solving for p, Initial residual = 0.000235522, Final residual = 2.34465e-06, No Iterations 150 GAMG: Solving for p, Initial residual = 0.000113833, Final residual = 1.1541e-06, No Iterations 300 DICPCG: Solving for p, Initial residual = 5.60628e-05, Final residual = 9.92177e-07, No Iterations 118 time step continuity errors : sum local = 6.62022e-17, global = -2.44787e-18, cumulative = 1.23481e-16 DILUPBiCGStab: Solving for omega, Initial residual = 3.96401e-16, Final residual = 9.82392e-31, No Iterations 3 DILUPBiCGStab: Solving for k, Initial residual = 9.78711e-12, Final residual = 9.84719e-28, No Iterations 3 bounding k, min: 0 max: 946.689 average: 2.30207 DILUPBiCGStab: Solving for ReThetat, Initial residual = 5.55254e-10, Final residual = 2.83376e-28, No Iterations 3 DILUPBiCGStab: Solving for gammaInt, Initial residual = 6.20827e-11, Final residual = 9.70914e-31, No Iterations 3 PIMPLE: converged in 2 iterations ExecutionTime = 374.59 s ClockTime = 375 s forces forces write: Sum of forces Total : (1.61885e+07 -2.42372e+07 7.42024e+06) Pressure : (1.61885e+07 -2.42372e+07 7.4202e+06) Viscous : (-49.2526 49.8269 37.1996) Sum of moments Total : (-2.93299e+07 3.23877e+08 3.04495e+06) Pressure : (-2.93289e+07 3.23878e+08 3.04493e+06) Viscous : (-983.493 -1277.54 19.7219) volFieldValue minmaxdomain_scalar write: volFieldValue mindomain_scalar write: min(region0) of p = -2.11475e+08 volFieldValue maxdomain_scalar write: max(region0) of p = 2.36003e+08 Miscellaneous: - SRFProperties: Code:
SRFModel rpm; origin (0 0 0); axis (0 1 0); rpmCoeffs { rpm 15; } - boundary Code:
7 ( BLADE { type wall; inGroups 1(wall); nFaces 84769; startFace 46191188; } INLET { type patch; inGroups 1(patch); nFaces 59648; startFace 46275957; } HUB { type patch; inGroups 1(patch); nFaces 59693; startFace 46335605; } OUTLET { type patch; inGroups 1(patch); nFaces 59648; startFace 46395298; } SIDE_LEFT { type cyclicAMI; inGroups 1(cyclicAMI); nFaces 59136; startFace 46454946; matchTolerance 0.0001; transform rotational; neighbourPatch SIDE_RIGHT; rotationAxis (0 1 0); rotationCentre (0 0 0); } SIDE_RIGHT { type cyclicAMI; inGroups 1(cyclicAMI); nFaces 55552; startFace 46514082; matchTolerance 0.0001; transform rotational; neighbourPatch SIDE_LEFT; rotationAxis (0 1 0); rotationCentre (0 0 0); } TOP { type patch; inGroups 1(patch); nFaces 62904; startFace 46569634; } ) Urel: inlet - SRFVelocity, top - SRFFreestreamVelocity, outlet - pressureInletOutletVelocity blade - noSlip p: outlet - fixedValue zeroGradient everywhere else Thanks in advance, let me know if more information is needed Christoph Figures: |
Writing out source term, coriolis and centrifugal in SRFPimpleFoam | Madeleine C | OpenFOAM Programming & Development | 1 | September 12, 2020 18:47 |
Flow in a uniformly rotating crucible using SRFPimpleFoam in OpenFoam | ashrujit | OpenFOAM Running, Solving & CFD | 0 | February 17, 2020 11:13 |
Adding Euler Force to SRFPimpleFoam (SRF) Model | sters_merlin | OpenFOAM Programming & Development | 0 | April 29, 2019 18:04 |
SRFPimpleFoam | eric_trw82 | OpenFOAM Running, Solving & CFD | 0 | September 18, 2018 14:13 |
pressure calculation SRFPimpleFoam | reichse | OpenFOAM Running, Solving & CFD | 0 | June 17, 2013 03:25 |
