Tips on running cases with interFoam
Hello Foamers,
I have just started using interFoam. I have some questions I would appreciate some help with. 1. When running cases with interFoam using the pimple algorithm with momentum predictor active, can I use relaxationFactors? Will they distort the physics if used? 2. In some of may test cases, the simulations diverge in the first time step. However, if I use setFields to fill the first layer of cells near the inlet, the simulation runs smoothly until the end. Is this a valid approach? |
