March 29, 2022, 17:17 |
Dynamic mesh refinement failing in interFoam
Venkat Ganesh
Rep Power: 5 |
I'm running a simple bubble growth case, which is running perfectly fine without the dynamic mesh refinement. I'm using a grid size of 0.02*0.02mm generated by blockMesh for the simulation.
I've adaptive time stepping turned on with a maxCo set at 0.5, while running with the dynamicMeshDict, I'm noticing that the deltaT starts dropping drastically after a point (upto 1e-53 or 1e-119) and the program crashes with floating point exception error. Also even while the program is running normally, the deltaT is much higher than a much finer grid (around 2 e-7). I've run with a fine grid of 0.01*0.01mm generated by blockMesh without dynamic mesh and it's running perfectly fine, and the average deltaT is also higher (around 2e-6). I'm sharing my dynamicMeshDict here. I'd really appreciate if someone could share their inputs. I see that a lot of them are facing the same issue with dynamic mesh refinement but there has been no resolution posted. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "constant"; object dynamicMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dynamicFvMesh dynamicRefineFvMesh; // How often to refine refineInterval 5; // Field to be refinement on field alpha.water; // Refine field in between lower..upper lowerRefineLevel 0.001; upperRefineLevel 0.999; // If value < unrefineLevel unrefine unrefineLevel 0.001; // Have slower than 2:1 refinement nBufferLayers 3; // Refine cells only up to maxRefinement levels maxRefinement 1; // Stop refinement if maxCells reached maxCells 250000; // Flux field and corresponding velocity field. Fluxes on changed // faces get recalculated by interpolating the velocity. Use 'none' // on surfaceScalarFields that do not need to be reinterpolated. correctFluxes ( (phi none) (nHatf none) (rhoPhi none) (alphaPhi0.water none) (ghf none) ); // Write the refinement level as a volScalarField dumpLevel true; // ************************************************************************* // |
July 17, 2022, 05:16 |
Al Csc
Rep Power: 7 |
Simple guess: are you running a 3D refinement in a 2D case?
Display Modes | |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[snappyHexMesh] Edge Refinement | fracasce | OpenFOAM Meshing & Mesh Conversion | 3 | December 2, 2017 13:30 |
Local mesh refinement definition in a DEFORMING dynamic mesh zone using Dynamic Mesh | Emanuele88 | FLUENT | 0 | February 9, 2016 11:39 |
How to know mesh size after dynamic refinement | tayo | OpenFOAM | 16 | May 22, 2013 13:39 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
