May 8, 2020, 05:53 |
potentialFoam, erasing the U and p fields
#1 | |
Franco
Rep Power: 6 |
hello,
I am trying to use potentialFoam to initialize my case and have a better initial field for simpleFoam for a laminar flow. for this to my fvSolution i added in the solvers phi {$p} so it use the same solver of p field and the potentialFlow{nNonOrthogonalCorrectors 3;} i have my 0.orig folder that i copy to the 0 and then run potentialFoam and then run simpleFoam. the issue I am facing is that when i run the potentialFoam application, it erases the initial field from the (U and p file that is in the 0 folder) and also the inlet boundary goes from fixedValue, value uniform (...) to fixedValue, value nonuniform 0(); . i do not understand what i am doing wrong, i am attaching the U and p files before and after potentialFoam, and also my controlDict, fvSolution and fvSchemes files. the geometry is a quarter of cylinder with two symetry planes. also copy the log of potentialFoam appli: Quote:
May 8, 2020, 06:20 |
Herpes Free Engineer
Rep Power: 12 |
Executing potentialFoam will overwrite the U field, and optionally p and phi fields (if you add options, e.g. "potentialFoam -writep"). potentialFoam solves for the "velocity potential" (Wikipedia), and derives a new velocity field from it. That's why "U" boundary content is changed from "uniform" to "nonuniform" with new values. As a side note, I have been using potentialFoam to initialise viscous computations, but never laminar computations. Would you teach us why would executing potentialFoam would be helpful for laminar cases?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
May 8, 2020, 06:38 |
#3 | ||
Franco
Rep Power: 6 |
best regards. |
May 8, 2020, 06:47 |
Rep Power: 12 |
>> hope that I am misunderstanding and the sarcasm in the phrase it is only that I am misreading it.I wanted to have an initialFields that is better than only a uniform value, so it would speed up the conversion of the simulation and also as a scholar case to learn how to use it.
best regards. - There was zero sarcasm. My apologies for misunderstanding. I was just curious, and wanted to learn. - Could you please post the "U" file? Overwriting the inlet boundary may be leading to the same inlet boundary? Let's see.
May 8, 2020, 06:56 |
#5 | |||
Franco
Rep Power: 6 |
yes i post it in the zip file in the first post, but i can copy paste here: the first one is before doing potential (i put in the same quote the U and p file): Quote:
inlet {type fixedValue;value uniform (0 0 0.2);} to: inlet {type fixedValue;value nonuniform 0();} and the internalField goes from: internalField uniform (0 0 0.1); to: internalField uniform (0 0 0); best regards! |
May 8, 2020, 07:14 |
#6 | |
Rep Power: 12 |
Oh, ok, got you. Hmm..
- One issue seems to be that there is no potentialFoam iterations carried out for Phi: Quote:
- If the case is quick to run, would you try "potentialFoam -initialiseUBCs"? - Is z-direction the streamwise flow direction?
May 8, 2020, 11:18 |
#7 | ||
Franco
Rep Power: 6 |
so, i tried potentialFoam -initialiseUBCs with same results (and the files look the same): Quote:
May 8, 2020, 13:16 |
Rep Power: 12 |
- Could you please tell me whether it is possible for you to share the case? (if it is not confidential)?
May 8, 2020, 15:00 |
#9 |
Franco
Rep Power: 6 |
yeah no problem,you can use the Allrun scripts they work properly (it is OF v7)
May 8, 2020, 16:22 |
#10 |
Rep Power: 12 |
- To my finding, the "inlet" and "outlet" patches were mistakenly defined inside wall patch. Check "constant/boundary" file, and you will see that the "inlet" and "outlet" boundaries have zero faces. You can also visualise it in paraview by selecting the "wall" only. Hence, zero potentialFoam iterations. - EDIT: Besides, you may want to refine the surface edges of the cylinder by adjusting snapping settings etc. Please have a look at the forum for further information. Hope this helps.
May 9, 2020, 12:44 |
#11 | |
Franco
Rep Power: 6 |
yes i will have a look, best regards franco |
May 9, 2020, 12:47 |
#12 |
Rep Power: 12 |
pleasure - and good luck.
August 14, 2022, 12:24 |
#13 |
Giles Richardson
Rep Power: 13 |
why does it write the solution to the "0" dir, rather than to "1"
potentialfoam, simplefoam initialisation |
OpenFOAM v4.1 - farfield bc potentialFoam | jeytsav | OpenFOAM Running, Solving & CFD | 0 | November 23, 2016 09:06 |
potentialFoam doesnt start?! | Sway | OpenFOAM Running, Solving & CFD | 0 | July 2, 2015 07:48 |
a reconstructPar issue | immortality | OpenFOAM Post-Processing | 8 | June 16, 2013 11:25 |
an odd(at least for me!) reconstructPar error on a field | immortality | OpenFOAM Running, Solving & CFD | 3 | June 3, 2013 22:36 |
PostChannel | maka | OpenFOAM Post-Processing | 5 | July 22, 2009 09:15 |
