Troubleshooting oscillating flowrate through complex geometry |
September 14, 2022, 17:53 |
Luke Reid
Rep Power: 6 |
Hi all,
I am having a some difficulty troubleshooting an error and am hoping someone would be able to give some here can help. I have provided the details of the case below. Code:
[0] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #2 ? in /lib/x86_64-linux-gnu/libpthread.so.0 [0] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? [0] #4 Foam::tmp<Foam::DimensionedField<double, Foam::volMesh> > Foam::operator*<Foam::volMesh>(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::DimensionedField<double, Foam::volMesh> const&) at ??:? [0] #5 Foam::RASModels::kOmega<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() at ??:? [0] #6 ? in /usr/lib/openfoam/openfoam2006/platforms/linux64GccDPInt32Opt/bin/pimpleFoam [0] #7 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 [0] #8 ? in /usr/lib/openfoam/openfoam2006/platforms/linux64GccDPInt32Opt/bin/pimpleFoam CASE DETAILS I am trying to simulate an unsteady oscillatory airflow rate through an upper respiratory tract geometry. The geometry is meshed using snappyHexMesh with checkMesh output suggesting an OK mesh (checkMeshLog attached). This is solved using kOmega and pimpleFoam, I have attached my '0' and 'system' files for detail on set up. BC at inlet: p - zeroGradient k - fixedValue omega - fixedValue U - { type flowRateInletVelocity; volumetricFlowRate { type sine; frequency 0.266; amplitude 0.0016; scale 1; level 0; } } BC at outlet: p - fixedValue; uniform 0; k- zeroGradient omega - zeroGradient U - zeroGradient Additional information on error It appears when visualising the results, the flow changes direction (outlet to inlet) there is a spike in velocity at the outlet then the inlet (see velocity vectors in attached images). Also, there in a dramatic drop in timestep to maintain the Courant no < 0.5. This is my first time posting so let me know if there's any other useful information I can provide. I tried to convey what is necessary. I would really appreciate any help the forum has to offer as I have been stuck on this for months. Cheers, Luke |
[ANSYS Meshing] Help with meshing a complex geometry | amsys | ANSYS Meshing & Geometry | 2 | April 8, 2020 02:45 |
[ICEM] Complex geometry mesh general questions | Jack B | ANSYS Meshing & Geometry | 0 | August 14, 2019 13:44 |
[ICEM] Holes in complex ICEM geometry | alecbann | ANSYS Meshing & Geometry | 2 | April 4, 2019 03:40 |
Solving complex geometry with compressible flow | gfoam | FLUENT | 1 | May 19, 2017 14:56 |
how to deal with complex geometry using ICEM? | prayskyer | CFX | 3 | June 20, 2006 07:33 |
