Divergence in parallel running after case reconstruction |
#1 | ||
Hung
Rep Power: 5 ![]() |
Hi all!
I am running a simulation in a very complex geometry (human lung). Due to computer resources, I sometimes have to share clusters to other shared users. I constantly have to change my running processor number to 36, 72, 108, ... That's why I reconstruct and decompose the case again if I want to use different number of processor. My process is: 1. When someone asks for nodes, I stop my case (running in 108 cores) and reconstructPar -latestTime. 2. Then I decomposePar -latestTime the case to 36 cores and restart. This is when I face a divergence problem. You can refer to the following results. After the second decomposing, my max parallel Courant number is 10.791 at time 0.1424 and keep doubling until divergence. Quote:
Anyone has any idea? Thanks. |
Haitham Osman
Rep Power: 7 ![]() |
I got the same problem like you got. To solve it, I tried using "adjustTimeStep on" if you are using pimpleFoam solver and fix "maxCo 5.5"(as you want in your case). This option would control the sharp increase in the courant number
![]() I hope it help any one got the same issue in future ![]() |
Display Modes | |
[mesh manipulation] Case diverges after running renumberMesh in parallel | sita | OpenFOAM Meshing & Mesh Conversion | 1 | June 26, 2019 07:24 |
Running AMI case in parallel | Kaskade | OpenFOAM Running, Solving & CFD | 3 | March 14, 2016 15:58 |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Running in parallel | Djub | OpenFOAM Running, Solving & CFD | 3 | January 24, 2013 16:01 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
