September 7, 2019, 11:59 |
dynamics lib link error
Nguyen Duy Trong
Rep Power: 12 |
Hi everyone,
I built a new library in OpenFOAM v5 and stored at $FOAM_USER_LIBBIN. However, when I call this library into solver of interFoam in ControlDicts, the program shows errors like this: --> FOAM Warning : From function void* Foam::dlOpen(const Foam::fileName&, bool) in file POSIX.C at line 1236 dlopen error : /home/ndtrong/OpenFOAM/ndtrong-5.0/platforms/linux64GccDPInt32Opt/lib/libdynamicFvMeshUser.so: undefined symbol: _ZTIN4Foam13dynamicFvMeshE --> FOAM Warning : From function bool Foam::dlLibraryTable:pen(const Foam::fileName&, bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 105 could not load "libdynamicFvMeshUser.so" It is appreciated if could someone guide me how to fix this error. Thanks |
October 4, 2022, 09:29 |
JABER ALSULAMI
Did you know the answer because I have the same issue?
thanks |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 00:10 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
