Problem horizontal separator -multiphaseEulerFoam
Old   November 12, 2022, 14:35
Default Problem horizontal separator -multiphaseEulerFoam
Humberto
humber11 is on a distinguished road
Hello
I'm trying to simulate a separator (water, oil and air) in the multiphaseEulerFoam, but I face a problem of divergence very fast, I believe it's a problem in the boundary conditions, but I don't find the error, if anyone can help me, I'd appreciate it.
Note: in multiphaseInterFoam the simulation worked.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      phaseProperties;
type basicMultiphaseSystem;
phases (water oil air);
water
    type            purePhaseModel;
    diameterModel   constant;
    constantCoeffs
        d               1e-4;
    residualAlpha 1e-3;
oil
    constantCoeffs
        d               1e-4;
    residualAlpha 1e-3;
air
    constantCoeffs
        d              3e-3;
    residualAlpha 1e-3;
blending
   default
        type            none;
        minFullyContinuousAlpha.oil 0.7;
        minPartlyContinuousAlpha.oil 0.3;
        minFullyContinuousAlpha.water 0.7;
        minPartlyContinuousAlpha.water 0.3;
        minFullyContinuousAlpha.air 0.7;
        minPartlyContinuousAlpha.air 0.3;
surfaceTension
    (air and water)
        type            constant;
        sigma           0.07;
    (air and oil)
        type            constant;
        sigma           0.032;
    (water and oil)
        type            constant;
        sigma           0.03;
interfaceCompression
aspectRatio
drag
virtualMass
heatTransfer
phaseTransfer
lift
wallLubrication
turbulentDispersion
// Minimum allowable pressure
pMin            10000;
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p_rgh;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
 inlet
       type            fixedFluxPressure;
    	value           $internalField;
    outletFluid1
        type            totalPressure;
        p0              $internalField;
        U               U.water;
        phi             phi.water;
        rho             thermo:rho.water;
    outletFluid2
        type            totalPressure;
        p0              $internalField;
        U               U.oil;
        phi             phi.oil;
        rho             thermo:rho.oil;
    walls
    outlet_air
        type            totalPressure;
        p0              $internalField;
        U               U.air;
        phi             phi.air;
        rho             thermo:rho.air;
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
	inlet
        type            calculated;
    outletFluid1
        type            calculated;
    outletFluid2
        type            calculated;
    walls
        type            calculated;
    outlet_air
        type            calculated;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.water;
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 1;
boundaryField
    inlet
    	type			fixedValue;
    	value           uniform 0.5;
    outletFluid1
        type            inletOutlet;
        phi             phi.water;
        inletValue      uniform 1;
        value           uniform 1;
    outletFluid2
        type            inletOutlet;
        phi             phi.water;
        inletValue      uniform 0;
        value           uniform 0;
    walls
        type            zeroGradient;
        outlet_air
        type            inletOutlet;
        phi             phi.water;
        value           uniform 0;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.oil;
internalField   uniform 0;
boundaryField
    inlet
    	type			fixedValue;
    	value           uniform 0.5;
    outletFluid1
        type            inletOutlet;
        phi             phi.oil;
        value           uniform 0;
    outletFluid2
        type            inletOutlet;
        phi             phi.oil;
        value           uniform 1;
    walls
        type            zeroGradient;
    outlet_air
        type            inletOutlet;
        phi             phi.oil;
        value           uniform 0;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      alpha.air;
boundaryField
	inlet
    	type			fixedValue;
    	value           uniform 0;
    outletFluid1
        type            inletOutlet;
        phi             phi.air;
        value           uniform 0;
    outletFluid2
        type            inletOutlet;
        phi             phi.air;
        value           uniform 0;
    walls
        type            zeroGradient;
    outlet_air
        type            inletOutlet;
        phi             phi.air;
        value           uniform 1;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U.air;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
	inlet
        type           fixedValue;
    outletFluid1
        type            pressureInletOutletVelocity;
        phi             phi.air;
    outletFluid2
        phi             phi.air;
    walls
        type            noSlip;
        outlet_air
        phi             phi.air;
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      U.oil;
boundaryField
inlet
        type            fixedValue;
        value           uniform (4 0 0);
    outletFluid1
        phi             phi.oil;
    outletFluid2
        phi             phi.oil;
    walls
        type            noSlip;
       outlet_air
        phi             phi.oil;
    version     2.0;
    format      ascii;
    location    "0";
    object      U.water;
boundaryField
	inlet
        type            fixedValue;
        value           uniform (5 0 0);
    outletFluid1
        phi             phi.water;
    outletFluid2
        phi             phi.water;
    walls
        type            noSlip;
       outlet_air
        phi             phi.water;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.*"
        nAlphaCorr      1;
        nAlphaSubCycles 4;
    p_rgh
        solver          PBiCGStab;
        preconditioner  DIC;
        tolerance       1e-07;
        relTol          0;
    p_rghFinal
        $p_rgh;
        relTol          0;
    "U.*"
        solver          PBiCGStab;
        spreconditioner  DIC;
        tolerance       1e-5;
        relTol          0;
    "e.*"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          2;
      //  maxIter         0;
        minIter         0;
PIMPLE
    nOuterCorrectors 1;
    nCorrectors         3;
    nNonOrthogonalCorrectors 0;
relaxationFactors
    equations
        ".*"            1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    "div\(phi,alpha.*\)"    Gauss vanLeer;
    "div\(phir,alpha.*,alpha.*\)"   Gauss vanLeer;
    "div\(alphaRhoPhi.*,U.*\)"      Gauss limitedLinearV 1;
    "div\(phi.*,U.*\)"              Gauss limitedLinearV 1;
    "div\(alphaRhoPhi.*,(h|e).*\)"  Gauss limitedLinear 1;
    "div\(alphaRhoPhi.*,K.*\)"      Gauss limitedLinear 1;
    "div\(alphaPhi.*,p\)"           Gauss limitedLinear 1;
    "div\(\(\(\(alpha.*\*thermo:rho.*\)*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)" Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     multiphaseEulerFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         20;
deltaT          0.001;
writeControl    adjustableRunTime;
writeInterval   0.1;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  no;
maxCo           0.5;
maxDeltaT       1e-2;
I use BlueCFD, does anyone know the meaning of these errors?
1)ZN4Foam11phaseSystem5solveERKNS_7PtrListINS_14Ge ometricFieldIdNS_12fvPatchFieldENS_7volMeshEEEEERK NS1_INS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEEE E
2)ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tm pINS_14GeometricFieldIdT_T0_EEEERKS7_SA_
Backtrace:
        ZN10StackTraceC1Ev [0x626c1855+0x25]
                 module: C:\PROGRA~1\BLUECF~2\ThirdParty-8\platforms\mingw_w64GccDPInt32\lib\libstack_trace.dll
        ZN4Foam5error10printStackERNS_7OstreamE [0x6c30ae5a+0x23a]
                 module: C:\PROGRA~1\BLUECF~2\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libOpenFOAM.dll
        ZN4Foam6sigFpe13sigFpeHandlerEi [0x6c30b693+0x33]
        (No symbol) [0x409412]
                 module: C:\PROGRA~1\BLUECF~2\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\bin\multiphaseEulerFoam.exe
        _C_specific_handler [0x7ffd3bf17ff8+0x98]
                 module: C:\WINDOWS\System32\msvcrt.dll
        0_chkstk [0x7ffd3c07241f+0x11f]
                 module: C:\WINDOWS\SYSTEM32\ntdll.dll
        RtlRaiseException [0x7ffd3c0214a4+0x434]
        KiUserExceptionDispatcher [0x7ffd3c070f4e+0x2e]
        ZN4Foam6divideERNS_5FieldIdEERKNS_5UListIdEES6_ [0x6c2bbf56+0x26]
        ZN4FoamdvINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS7_SA_ [0x61eff86f+0x25f]
                 module: C:\PROGRA~1\BLUECF~2\OpenFOAM-8\platforms\mingw_w64GccDPInt32Opt\lib\libphaseSystem.dll
        ZN4Foam11phaseSystem5solveERKNS_7PtrListINS_14GeometricFieldIdNS_12fvPatchFieldENS_7volMeshEEEEERKNS1_INS2_IdNS_13fvsPatchFieldENS_11surfaceMeshEEEEE [0x61df06d3+0x4b43]
        (No symbol) [0x472431]
        (No symbol) [0x4013c1]
        (No symbol) [0x4014f6]
        BaseThreadInitThunk [0x7ffd3bb974b4+0x14]
                 module: C:\WINDOWS\System32\KERNEL32.DLL
        RtlUserThreadStart [0x7ffd3c0226a1+0x21]
humber11 is offline   Reply With Quote
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
BuoyantBoussinesqSimpleFoam_Facing problem Mondal131211 OpenFOAM Running, Solving & CFD 1 April 10, 2019 20:41
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 14:52
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
@ horizontal silencer damping problem vivek p patil CFX 0 June 12, 2006 04:31
