SprayFoam: negative courant number, mesh ok
Hi;
I am running a simulation with sprayFoam (OpenFoam 8) and I receive this error: Code:
Courant Number mean: -1.373865 max: 2.614777e+04 the checkMesh is ok without any error or warning, the checkMesh -allGeometry gives wellposedness error in some cells. On this mesh I have already performed a simulation with buoyantSimpleFoam, the mesh can be improved but is not bad at this state. The sprayCouldProperties has been used in another simulation without generating this error; the source point is on a boundary surface and the direction (of the particles and the surface normal too) is inside the domain. I know the max courant number should be reduced, but the cells with the highest courant number are not near the particle source. my question are: 1)the negative courant number is linked with the error below it or are two different errors? 2) do you know how can i resolve this problem? thanks a lot for your help, and let me know if you need additional informations |
