Euler-Euler approach - multiphase problem
1 Attachment(s)
Is it possible to model a multiphase problem (more than two phases) with an Euler-Euler approach in OpenFOAM? What is the solver?
I left an example of the problem I'm studying. **Is there any DES solver in OpenFOAM for multiphase problems? |
Can anyone help me?
Hey :)
I am not sure about DES, but multiphaseEulerFoam does what its name suggests, you should check it out. If you have only two phases, there is also a variant twoPhaseEulerFoam in the tutorials. Once you have your setup up and running you can maybe try to swap the turbulence model and see if it accepts DES models. Good luck! |
