Nikos
Rep Power: 14 ![]() |
Hi, I am trying to simulate a conjugate heat transfer problem with four solid regions heated by six propeller fans (simulated as MRF zones).
I have created my geometry using snappyHexMesh. I have also declared the MRF zones at the snappyHexMeshDict, e.g. for the first MRF zone in the refinementSurfaces sub-dictionary: Code:
AMI1 { level (1 1); cellZone rotatingZone1; faceZone rotatingZone1; cellZoneInside inside; } Code:
splitMeshRegions -cellZones -overwrite The rotation velocity is declared at the MRFProperties (in constant\Air), e.g. for the first MRF zone: Code:
MRF1 { cellZone rotatingZone1; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (); origin (2.59793 3.940 11.37112); axis (0.0 1.0 0.0); omega -120; } Code:
Adding MRF Creating MRF zone list from MRFProperties creating MRF zone: MRF1 creating MRF zone: MRF2 creating MRF zone: MRF3 creating MRF zone: MRF4 creating MRF zone: MRF5 creating MRF zone: MRF6 Adding fvOptions I note here that the same configuration (with a similar snappyHexMeshDict and MRFProperties) is working perfectly with the simpleFoam solver (just for the flow problem in this case). My openFoam version is v2012. Any clues of what is missing? Thanks in advance! Nikos Last edited by nikoscham; January 23, 2023 at 10:49. |
Nikos
If anyone is interested, I have found a solution for this problem. I realized that the MRF cellZones weren't defined. So, I defined them manually by using topoSet.
Lukas
Rep Power: 5 ![]() |
A short note on your Problem + Fixing,
you can work with splitMeshRegions -cellZonesfile to specifiy a cellzone file where u have fluid + 4 solids and actually your "realfile" also holds the mfrs from snappyHex then you can keep the mfrzones during splitting ! greetings |
Display Modes | |
MRF and steady state solution | worldsheep | Main CFD Forum | 3 | August 18, 2021 07:33 |
Modeling Wheel Rotation using MRF | Lukas7117 | FLUENT | 0 | December 1, 2020 10:19 |
Simulation of Radial Fan with simpleFoam MRF | nash | OpenFOAM Running, Solving & CFD | 2 | November 5, 2015 10:12 |
UDF is working in Laptop, but not working in Serial Cluster | Tanjina | Fluent UDF and Scheme Programming | 0 | December 20, 2013 21:42 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
