chtMultiRegionTwoPhaseEulerFoam: Nucleate Boiling
Like Tree1Likes
  • 1 Post By govind_IITD
Old   March 1, 2023, 03:20
Default chtMultiRegionTwoPhaseEulerFoam: Nucleate Boiling
Goind Sharma
govind_IITD is on a distinguished road
I am working on boiling heat transfer phenomenon with conjugate heat transfer as well. I am following the tutorial of chtMultiRegionTwoPhaseEulerFoam (Solid quenching) as starting point. I am not sure about the boundary conditions which are imposed and the phase properties.
Geometry of the considered problem is just a rectangular cross-section type. I am attaching the case directory.
Please look at this. Following this, I will look into effect of the solid wall thickness on the boiling phenomenon.
I want to visualize the rising bubbles from the boiling process.
Regards,
Govind
govind_IITD is offline   Reply With Quote
Old   March 9, 2023, 03:09
Default Contd
Goind Sharma
I worked on that and replaced the previous case with vertical wall boiling. I resolved to some extent boundary conditions' issue. But now, I ran into different of problem. When I execute the chtMultiRegionTwoPhaseEulerFoam, it gives:
Selecting phaseModel for gas: purePhaseModel
Selecting diameterModel for phase gas: isothermal
Selecting thermodynamics package
type heRhoThermo;
mixture pureMixture;
transport const;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleEnthalpy;
Foam::heRhoThermo<Foam::rhoThermo, pureMixture<Foam::constTransport<Foam::species::th ermo<Foam::hConstThermo<perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, bool) at ??:?
oam::twoPhaseSystem::adddictionaryConstructorToTab le<Foam::ThermalPhaseChangePhaseSystem<Foam::Phase TransferPhaseSystem<Foam::TwoResistanceHeatTransfe rPhaseSystem<Foam::MomentumTransferPhaseSystem<Foa m::twoPhaseSystem> > > > >::New(Foam::fvMesh const&) at ??:?
Floating point exception (core dumped).
I am not getting any clue about this.
Regards,
Govind
roshan6890 likes this.
Old   March 13, 2023, 03:56
Default Contd
Goind Sharma
I, myself, solved the issues pertaining with boundary conditions. It was some daunting task but got to know many things. As solver is running, but I am working on to get the physically correct solution.
Actually, what I think that pressure boundary conditions for "p" and "prgh" need to be validated correctly. I am solving the "wall heating" problem from "CFD simulation of conjugate heat transfer with flull boiling in OpenFOAM" for high pressure mass flow rate. Input of the problem as:
mass flow rate = 900 kg/s
Pressure = 4.5MPa.
Another issue, I am facing the "nut" condition. If I use laminar flow then its fine, but not with turbulent flow.
Any suggestion will be helpful.
Regards,
Govind
Old   February 6, 2024, 22:28
Oscar Zagal
oscar_zagal is on a distinguished road
Hello Govind, what version of OpenFOAM do you use?, in the version that I use (OF4Win 20.09) the solver chtMultiRegionTwoPhaseEulerFoam is not included.
Thanks in advance.
oscar_zagal is offline   Reply With Quote
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 12:42
How to make UDFs for Nucleate Pool Boiling Simulation? SIKJAE Fluent UDF and Scheme Programming 1 August 4, 2018 08:07
Two-phase Eulerian model for nucleate subcooled boiling Edy OpenFOAM 5 February 11, 2017 17:21
OpenFOAM UpdateCoeffs Nucleate Wall Boiling suneth.warna OpenFOAM Programming & Development 0 July 31, 2016 18:42
nucleate boiling simulation in CFX Anil CFX 3 August 25, 2010 15:18
