fvOptions is not working
2 Attachment(s)
I am trying to observe unsteady, laminar and incompressible flow through an axisymmetric periodic tube. I am using periodic boundary conditions (cyclicAMI) at the inlet and outlet. I am using OpenFoam Version10. I would like to create an oscillatory flow using sinusoidal time varying functions in fvOptions. I have created the fvOptions file as in the attachment and put it in the system folder. However, it is not working. I appreciate your kind suggestion in this regards. Cheers |
I think there are at least 2 problems in your simulation:
Have a look at the models available with fvModels which might fit what you are trying to do. accelerationSource sounds like a good option: https://github.com/OpenFOAM/OpenFOAM...rationSource.H Cheers, Yann |
Hi Yann, Many thanks for your kind response and for making clear about uniformFixedValue and fvOptions. I will follow your direction and will see whether I get my desired flow using accelerationSource. Cheers |
2 Attachment(s)
Hi Yann,
I am trying to run the solver pimplefoam with accelerationSource. I have prepared the fvModels file as you can see in the attachment and put it in the constant folder. However, I am getting the fatal error as you see in the attachemnt while I am running the solver. Could you please suggest me in this regard? |
There is a semicolon missing at the end of the "version" line, which prevents OpenFOAM to properly read the next line (format). You can remove the version line which shouldn't be mandatory anymore in OpenFOAM-10: Code:
FoamFile Yann |
Hi Yann, Many thanks for identifying the problem. It is working now. Cheers, Nazmul |
1 Attachment(s)
Hi Yann,
I have tried to implement the accelerationSource along with sine function (instead of halfCosineRamp function) to make sinusoidally varying oscillating flow. However, it seems to me that it is not working as I expect, that is, it is not creating sinusoidally oscillating flow. Please see the fvModels in the attachment. I am not clear about the "value" which has been taken as (-2.572 0 0) in the fvModels file. Could you please give me the idea about this "value" and why it is not creating sinusoidally oscillating flow? I really appreciate your kind cooperation in this regard. Cheers, Nazmul |
Hello Nazmul,
I never used accelerationSource so I don't know how it works exactly. Since there is a line "velocity scale;", I guess the sine function should be used to scale the velocity set in value. Regards, Yann |
Hello Yann, Thanks for your explanation. I was using the solver pimpleFoam in the tutorial plannarPoiseuile which was making problem to produce sinusoidally oscillating flow. Now, I am using the solver pimpleFoam with the tutorial pitzDailyPulse and using fvModels file in the constant folder. And I am getting now sinusoidally oscillating flow. However, still I am struggling to understand the underlying principle how it works. It says in accelerationSource.H file that "This fvModel applies an explicit acceleration force to components of the velocity field." So, it seems to this fvModels accelerate or deaccelerate the velocity components by adding as a source term to the existing (velocity at previous time step) velocity. However, many thanks for your valuable suggestion which help to produce oscillatory flow. Cheers, Nazmul |
