internal velocity doesn't change in rhocentralfoam
I am currently running supersonic free stream simulation on rhocentralfoam
However, when I try to set velocity of internal field over mach 1, e.g. 1.5, It crashes with error 'Negative initial temperature' while calculating e So, I reduced initial velocity to M 0.8, and set boundary to 1.5 so shock doesn't occur initially on the body and crash the computation, but it can slowly converge to result. It did converge, but when I postprocess and watch it, it shows internal flow velocity is below M1 everywhere. I set inlet to supersonicFreestream boundary condition, and outlet as inletOutlet . Is there way to get rid of 'Negative initial temperature' problem, or make internalfield adapt to boundary condition velocity value, which is 1.5? |
