mpirun no longer works on v2006!
Hi All,
I am using OpenFoam v2006 on a CentOS machine. Recently I cannot run any cases in parallel (including tutorial cases). It seems like mpirun is broken. The commands just hang and nothing is written to the log file. Could somebody double check a parallel tutorial case with v2006 to see if this is a local problem? Thank you very much! |
mpirun is not part of openfoam, it is part of openmpi
If it no longer works then check your installation |
