marineone |
June 15, 2023 11:25 |
Segfault when using codedFixedValue and decomposePar
Hello guys,
I am trying to simulate a flow over a wall mounted cube. The flow domain is simple box around this cube which I have generated with blockMesh. Now I want to use the codedFixedValue functionality to have a time dependent velocity BC at the inlet as can be seen below.
inlet
type codedFixedValue;
value uniform (0 0 0);
name periodicInletVel;
codeOptions
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude
codeInclude
#include "fvCFD.H"
#include <cmath>
#include <iostream>
#include "vector.H"
code
const fvPatch& boundaryPatch = this->patch();
const vectorField& Cf = boundaryPatch.Cf();
vectorField& field = *this;
const scalar t = this->db().time().value();
const scalar speed = 5;
forAll(Cf, faceI)
field[faceI] = sin(t) * vector(speed, 0, 0);
Trying to decompose the mesh in 8 equal parts with this code
numberOfSubdomains 8;
method simple;
// method metis;
// method ptscotch;
simpleCoeffs
n (2 2 2);
delta 0.001;
hierarchicalCoeffs
n (1 1 1);
delta 0.001;
order xyz;
manualCoeffs
metisCoeffs
leads to a Segmentation fault error. I could not figure out where exactly the problem occurs:
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::Hasher(void const*, unsigned long, unsigned int) at ??:?
#4 Foam::HashTable<Foam::tmp<Foam::fvPatchField<Foam::Vector<double> > > (*)(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&), Foam::word, Foam::string::hash>::set(Foam::word const&, Foam::tmp<Foam::fvPatchField<Foam::Vector<double> > > (* const&)(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&), bool) at ??:?
#5 ? at 0/U/boundaryField/inlet:112
#6 ? in "/lib64/ld-linux-x86-64.so.2"
#7 ? in "/lib64/ld-linux-x86-64.so.2"
#8 ? in "/lib64/ld-linux-x86-64.so.2"
#9 ? in "/lib64/ld-linux-x86-64.so.2"
#10 ? in "/lib64/ld-linux-x86-64.so.2"
#11 ? in "/lib/x86_64-linux-gnu/libdl.so.2"
#12 ? in "/lib64/ld-linux-x86-64.so.2"
#13 ? in "/lib/x86_64-linux-gnu/libdl.so.2"
#14 dlopen in "/lib/x86_64-linux-gnu/libdl.so.2"
#15 Foam::dlOpen(Foam::fileName const&, bool) at ??:?
#16 Foam::dlLibraryTable::open(Foam::fileName const&, bool) at ??:?
#17 Foam::codedBase::loadLibrary(Foam::fileName const&, Foam::string const&, Foam::dictionary const&) const at ??:?
#18 Foam::codedBase::updateLibrary() const at ??:?
#19 Foam::fvPatchField<Foam::Vector<double> >::adddictionaryConstructorToTable<Foam::codedFixedValueFvPatchField<Foam::Vector<double> > >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#20 Foam::fvPatchField<Foam::Vector<double> >::New(Foam::fvPatch const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#21 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::Boundary::readField(Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, Foam::dictionary const&) at ??:?
#22 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields(Foam::dictionary const&) at ??:?
#23 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::readFields() at ??:?
#24 Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>::GeometricField(Foam::IOobject const&, Foam::fvMesh const&) at ??:?
#25 ? at ??:?
#26 ? at ??:?
#27 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#28 ? at ??:?
Segmentation fault
I already did some trial and error (e.g. excluding libraries, playing with the decomposeParDict values) and but none of them could fix the problem. Is there some additional code missing? Any help would be highly appreciated!
