FOAM Fatal Error : (OpenFOAM-2012)
Old   July 7, 2023, 03:39
Default FOAM Fatal Error : (OpenFOAM-2012)
NOR AMIRA HUSNA
amrhus is on a distinguished road
Hi all,
I want to install OpenFoam on my Windows 10 but when I finish the step and try to write the command simpleFoam and blockMesh using bash terminal on Windows 10, it appear the above error.
--> FOAM FATAL ERROR: (openfoam-2012)
cannot find file "/mnt/c/Users/User/tutorial/system/controlDict"
From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 547.
FOAM exiting
amrhus is offline   Reply With Quote
Old   July 7, 2023, 04:52
Yann
Yann will become famous soon enoughYann will become famous soon enough
You need to create a case directory and navigate to this directory in your terminal before running these commands.
If you are lost, I suggest to start with the tutorial guide: https://www.openfoam.com/documentation/tutorial-guide
Regards,
Yann
Yann is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
