Hydrostatic pressure in Capillary Rise Tutorial
Old   July 28, 2023, 20:44
Default Hydrostatic pressure in Capillary Rise Tutorial
Marcus
MarcusAng is on a distinguished road
Hi everyone,
I am having trouble understanding p_rgh and p results for interFoam.
Consider the tutorial case $FOAM_TUTORIALS/multiphase/interFoam/laminar/capillaryRise
From what I understand, p_rgh (Pa) is a modified pressure term that is defined such that it is more efficient to solve incompressible and compressible problems in multiphase flow. p_rgh term does not contain the hydrostatic pressure. On the other hand, p is the total gauge pressure (Pa) and should contain the hydrostatic pressure effects. Hydrostatic pressure w.r.t origin is rho*gh and therefore from the OpenFOAM documentation, the following equation is true
p' (i.e. p_rgh)=p-rho*gh
Now, if I want to submerge my capillary pipe initially (not fill up capillary tube), does it make sense to extend the capillary pipe in the negative z direction? And if so, does it make sense to still use p_rgh=0 as the inlet boundary condition?
Thanks,
Marcus
MarcusAng is offline   Reply With Quote
Generate convective pressure fluctuation Bananenflanke CFX 10 May 12, 2021 19:33
drastic reduction in volume flow rate while increasing Pressure rise Gkchpa Main CFD Forum 0 July 24, 2020 09:23
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
