Combining solidbody motion+ deforming mesh in the new OpenFOAM v11
Old   July 28, 2023, 23:37
Default Combining solidbody motion+ deforming mesh in the new OpenFOAM v11
TWB
quarkz is on a distinguished road
I need to combine solidbody motion+ deforming mesh in the new OpenFOAM v11. OpenFOAM ESI can already do it but I need to use AMI and it has some problems.
Hence, I would like to try the new OF v11 which has a new dynamicMesh and NCC capability.
Either one works well but when I combine them, the mesh gets distorted.
FYI, I'm simulating a 2D airfoil which plunges up/down (solid motion) and the flap rotates up/down (deformation). The dynamicMeshDict is:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
mover
    type            motionSolver;
    libs            ("libfvMeshMovers.so" "libfvMotionSolvers.so" "librigidBodyMeshMotion.so");
	motionSolver    motionSolverList;
	solvers
        linear
            motionSolver    solidBody;
            //select          all;
			cellZone	AirfoilZone;
            solidBodyMotionFunction  oscillatingLinearMotion;
            amplitude     (0 0.5 0);
            omega         6.24;
            //rpm           60;
		flap_rotate
            motionSolver    displacementLaplacian;
            //select          all;
            diffusivity  quadratic inverseDistance 1(flap_wall);
and the pointDisplacement file is:
FoamFile
    version     2.0;
    format      binary;
    class       pointVectorField;
    arch        "LSB;label=32;scalar=64";
    location    "0";
    object      pointDisplacement;
dimensions      [0 1 0 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    airfoil_wall
        type            fixedValue;
        value           uniform (0 0 0);
    flap_wall
        type            angularOscillatingDisplacement;
        value           uniform ( 0 0 0 );
        axis            ( 0 0 1 );
        origin          ( 1.02 0 0.02 );
        angle0          0;
        amplitude       0.358;
        omega           6.28;
    inlet
        type            fixedValue;
    outlet
        type            fixedValue;
    BaseAndTop
        type            empty;
I wonder if it is possible at all although it's mentioned that it's possible to combine them together.
quarkz is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Wankel rotor Deforming mesh and motion UDF_Help please Catthan FLUENT 1 August 3, 2011 09:04
Automatic Mesh Motion solver michele OpenFOAM Running, Solving & CFD 10 September 26, 2005 09:21
