"error while loading shared libraries" error when running simpleFoam in parallel
I am putting together a cluster of 20 physical computers, each containing 4 cores. Right now I am trying to get the master and the first node (acl-n1) working. I am using MPI and NFS.
From my understanding, the openfoam9 dir should be in my shared folder OpenFOAM. I have updated the bashrc in openfoam9/etc/bashrc to correspond with the new dir. Some context info: $PATH /home/mpiuser/.local/bin:/path/to/openmpi/bin:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/gperftools-svn/bin:/opt/paraviewopenfoam56/bin:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/cmake-*/bin:/home/mpiuser/OpenFOAM/mpiuser-9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/site/9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin:/home/mpiuser/OpenFOAM/openfoam9/bin:/home/mpiuser/OpenFOAM/openfoam9/wmake:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin $LD_LIBRARY_PATH /home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64Gcc/gperftools-svn/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/paraview-5.6:/opt/paraviewopenfoam56/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64GccDPInt32/lib/openmpi-system:/usr/lib/x86_64-linux-gnu/openmpi/lib:/home/mpiuser/OpenFOAM/mpiuser-9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/site/9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib:/home/mpiuser/OpenFOAM/ThirdParty-9/platforms/linux64GccDPInt32/lib:/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/lib/dummy Shared folder that is mounted correctly on acl-n1: /home/mpiuser/OpenFOAM $FOAM_INST_DIR=/home/mpiuser/OpenFOAM $FOAM_RUN=$FOAM_INST_DIR/mpiuser-9/run $machines is: master acl-n1 I copied the tutorials dir to $FOAM_RUN, and im trying to run the airFoil2D case: Code:
mpirun --hostfile $machines -np 5 simpleFoam >> log Code:
-------------------------------------------------------------------------- If I specify where simpleFoam is exactly: Code:
mpirun --hostfile $machines -np 5 $FOAM_INST_DIR/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam >> log Code:
/home/mpiuser/OpenFOAM/openfoam9/platforms/linux64GccDPInt32Opt/bin/simpleFoam: error while loading shared libraries: libPstream.so: cannot open shared object file: No such file or directory Please help, I have been tearing out my hair for weeks on this!! |
