ChtMultiRegionFoam : pressure oscillating using a t junction geometry
2 Attachment(s)
Hello Foamers,
I'm trying to model a T-junction with conjugate heat transfer. The objective being able to run an LES simulation for a certain amount of time, I would like to initialize this case from a RANS computation. I've been able to run an equivalent of this case in FLUENT with a comparable mesh but I cannot reproduce the same convergence behavior in OpenFOAM. I tried switching from 2nd order to schemes to 1st order, testing different limiters as well as different linear solvers (GAMG/PCG) for pressure. I also used temperature Limits. In every configuration tested, the residuals for pressure keep oscillating as in the picture. Here is the result of checkMesh Mesh stats points: 680510 faces: 2013016 internal faces: 1985360 cells: 666396 faces per cell: 6 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 2 Overall number of cells of each type: hexahedra: 666396 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 1424 1463 ok (non-closed singly connected) outlet 1424 1463 ok (non-closed singly connected) solid_wall 23476 23587 ok (non-closed singly connected) top 1332 1369 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... CellZone Cells Points Volume BoundingBox fluid 381636 394196 0.033184772 (0 -0.07 -0.07) (2 0.38 0.07) solid 284760 306765 0.0071225423 (0 -0.077 -0.077) (2 0.38 0.077) Checking basic pointZone addressing... No pointZones found. Checking geometry... Overall domain bounding box (0 -0.077 -0.077) (2 0.38 0.077) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (1.1900187e-17 1.4072246e-15 -2.9427474e-17) OK. Max cell openness = 6.3700008e-16 OK. Max aspect ratio = 100.73856 OK. Minimum face area = 7.9176419e-07. Maximum face area = 0.00034169823. Face area magnitudes OK. Min volume = 3.28995e-09. Max volume = 2.2391697e-06. Total volume = 0.040307315. Cell volumes OK. Mesh non-orthogonality Max: 62.619621 average: 21.328153 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.9596531 OK. Coupled point location match (average 0) OK. Mesh OK. End If you want to test it on your side, the test case is available here: https://drive.google.com/file/d/1g3q...ew?usp=sharing Any idea ? Thank you in advance, |
