snappyHexmesh
Like Tree1Likes
  • 1 Post By AtoHM
Old   August 9, 2023, 05:14
Default snappyHexmesh
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Hi there,
I want to simulate flow over cylinder in openfoam, so i have faced with error along using snappyHexMesh. I have attached my procedures as well as snappyhexmesh code. please helpe me at this matter.
Thank you.
myfoam@DESKTOP-TK3D7CI:~$ cd OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder2D
myfoam@DESKTOP-TK3D7CI:~/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder2D$ blockMesh
| \\ / O peration | Version: 2112 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _6e1fca0e-20220610 OPENFOAM=2112 patch=220610 version=2112
Arch : "LSB;label=32;scalar=64"
Exec : blockMesh
Date : Aug 09 2023
Time : 11:35:59
Host : DESKTOP-TK3D7CI
PID : 1293
I/O : uncollated
Case : /home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder2D
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from "system/blockMeshDict"
Creating block edges
No non-planar block faces defined
Creating topology blocks
Creating topology patches - from boundary section
Creating block mesh topology
--> FOAM Warning :
From void Foam::polyMesh::setTopology(const cellShapeList&, const faceListList&, const wordList&, Foam::labelList&, Foam::labelList&, Foam::label&, Foam::label&, Foam::cellList&)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 369
Trying to specify a boundary face 4(0 4 5 1) on the face on cell 0 which is either an internal face or already belongs to some other patch. This is face 0 of patch 5 named bottom.
Check topology
Basic statistics
Number of internal faces : 0
Number of boundary faces : 7
Number of defined boundary faces : 7
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list (topological search)...
Deleting polyMesh directory "constant/polyMesh"
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale (1 1 1)
Block 0 cell size :
i : 0.03645899863251528 .. 0.04375079835901829
j : 0.02734424897438648 .. 0.03281309876926375
k : 0.6 .. 0.6
--> FOAM Warning :
Trying to specify a boundary face 4(0 1 442 441) on the face on cell 0 which is either an internal face or already belongs to some other patch. This is face 0 of patch 5 named bottom.
There are no merge patch pairs
Writing polyMesh with 0 cellZones
Mesh Information
boundingBox: (-0.2 -0.3 -0.3000000000000001) (0.6000000000000001 0.3 0.3000000000000001)
nPoints: 882
nCells: 400
nFaces: 1660
nInternalFaces: 760
Patches
patch 0 (start: 760 size: 20) name: inlet
patch 1 (start: 780 size: 20) name: outlet
patch 2 (start: 800 size: 20) name: cylinder
patch 3 (start: 820 size: 800) name: frontAndBack
patch 4 (start: 1620 size: 20) name: top
patch 5 (start: 1640 size: 20) name: bottom
End
myfoam@DESKTOP-TK3D7CI:~/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder2D$ snappyHexMesh
Exec : snappyHexMesh
Date : Aug 09 2023
Time : 11:36:08
PID : 1294
I/O : uncollated
nProcs : 1
Create time
Create mesh for time = 0
Read mesh in = 0 s
Overall mesh bounding box : (-0.2 -0.3 -0.3000000000000001) (0.6000000000000001 0.3 0.3000000000000001)
Relative tolerance : 1e-06
Absolute matching distance : 1.16619037896906e-06
Reading refinement surfaces.
Read refinement surfaces in = 0 s
Reading refinement shells.
Read refinement shells in = 0 s
Setting refinement level of surface to be consistent with shells.
Checked shell refinement in = 0 s
Reading features.
Read features in = 0 s
Determining initial surface intersections
Edge intersection testing:
Number of edges : 1660
Number of edges to retest : 0
Number of intersected edges : 0
Number of edges to retest : 1660
Number of intersected edges : 10
Calculated surface intersections in = 0 s
Initial mesh : cells:400 faces:1660 points:882
Cells per refinement level:
0 400
--> FOAM FATAL IO ERROR: (openfoam-2112 patch=220610)
Entry 'allowFreeStandingZoneFaces' not found in dictionary "/home/myfoam/OpenFOAM-sims/tutorials/incompressible/pimpleFoam/laminar/cylinder2D/system/snappyHexMeshDict.castellatedMeshControls"
file: system/snappyHexMeshDict.castellatedMeshControls at line 37.
From bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType::option, bool) const [with T = bool]
in file /usr/src/packages/BUILD/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 322.
FOAM exiting
saeed jamshidi is offline   Reply With Quote
Old   August 9, 2023, 05:20
M
AtoHM is on a distinguished road
Its missing the keyword as stated:
Look into a template to locate the keyword and add it in your snappyHexMeshDict.
Yann likes this.
AtoHM is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 07:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 17:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 03:09
