Supersonic -> Subsonic: how to set BCs
Old   September 7, 2023, 09:56
Default Pressure recovery: how to set BCs
K
mkhm is on a distinguished road
Hi foamers,
As the title suggests, I would like to transition from a low pressure at the inlet to a higher pressure at the outlet. However, this doesn't appear to be straightforward, and the velocity becomes negative (my problem is 1D). The reverse process (high pressure to low pressure) works perfectly. Applying the 'inletOutlet' boundary condition for velocity, in order to ensure that the inlet always remains as the inlet (U_x (inletValue) != 0 and U_x (value) = 0) and the outlet always remains as the outlet (U_x (value) != 0 and U_x (inletValue) = 0), does not provide a solution. Do you have any suggestions?
mkhm is offline   Reply With Quote
how to set BCs when u know p bcs but didn't know u bcs puppetbilly OpenFOAM Pre-Processing 0 April 6, 2022 00:49
how to set BCs when u know p bcs but didn't know u bcs puppetbilly OpenFOAM Running, Solving & CFD 0 April 6, 2022 00:46
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 08:00
Probelm with supersonic exhaust to ambient newj CFX 2 August 9, 2012 18:01
subsonic inlet or supersonic inlet? mali CFX 0 November 28, 2008 20:57
