adjointOptimisationFoam not converging
2 Attachment(s)
Hello everyone,
I use adjointOptimisationFoam to shape-optimize a geometry consisting of several cubes. The solver was slightly modified, the apparent porosity in the Navier-Stokes equation was removed. Compiling works and simulating other geometries also worked. My problem is that the adjoint system of equations does not converge and always diverges after a few 1000 iterations (due to large continuity error). The primal system converges. I have attached pictures of the primal and adjoint residuals. I tried the following: - Refine mesh - Vary relaxation factors - Increase cylinder diameter I will also try do increase the cylinder length before and after the geometry. Do you have any ideas what else I can try? This is my fvSolution: Code:
solvers Elvis |
