[Sponsors] | |||||
buoyantPimpleFoam diverges with the negative temperature |
Sina Rahimi
Rep Power: 0 ![]() |
I want to simulate a 3-D transient of external wind around buildings. The turbulent model was set K-epsilon. I tried to use the buoyantPimpleFoam solver in OpenFOAM 8, and after a few time steps, the solution diverges with the negative temperature error. I want to use buoyantPimpleFoam because I need to apply the Boussinesq approximation. The grid of the computational domain is shown in Figure. The output from checkMesh was OK. I think there is something wrong with pressure; I am not sure! I am new to OpenFoam, and any help would be highly appreciated. The BCs are attached in the 0 folder, and the other case setups are presented below: ** thermophysical properties: PHP Code:
PHP Code:
PHP Code:
Thank you!0.zip 1224.jpg 1324.jpg 1424.jpg Last edited by deathstar; February 2, 2024 at 16:04. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Negative temperature and pressure in sonicFoam :O | gallon | OpenFOAM Running, Solving & CFD | 17 | July 19, 2024 20:58 |
| [Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
| negative initial temperature/ exceeded number of max. iteratons | PSander | OpenFOAM Running, Solving & CFD | 0 | July 12, 2020 13:37 |
| UDF to Define Temperature Dependent Negative Heat Source | ATIKADAR | Fluent UDF and Scheme Programming | 1 | September 23, 2019 04:52 |
| [blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
