FOAM FATAL ERROR: field not found in table.
Hi Everyone,
I am running LES with OF 4.1 and faced this error after the first time step. Everything about the residual and the cumulative is ok, but it always will stop. I can run it again and after the next time step, will stop. Have you faced this error? FOAM FATAL ERROR: [13] <field not found in table. Valid entries: 7 ( R nuEff nut k epsilon devReff omega ) |
it was due to some functions I defined for postprocessing.
