Rep Power: 6 ![]() |
I am running a case using simpleFoam with a k-epsilon turbulence model, on a submarine stl geometry(named "hull" in my case). However, values of epsilon and k diverge quickly (after 5 iterations). I already check the mesh and tried to change the value of the time step but it doesnt solve my issue. Has anyone an idea on how to solve my problem? My files for k, epsilon, P, U and nut are: k: dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.00015; boundaryField { inlet { type fixedValue; value $internalField; } "(hull|top|bottom|side|side2)" { type kqRWallFunction; value $internalField; } outlet { type zeroGradient; } } epsilon: dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.00025; boundaryField { inlet { type fixedValue; value $internalField; } "(hull|top|bottom|side|side2)" { type epsilonWallFunction; value $internalField; Cmu 0.09; kappa 0.41; E 9.8; } outlet { type zeroGradient; } } nut: dimensions [0 2 -1 0 0 0 0]; internalField uniform 5e-07; boundaryField { "(hull|top|bottom|side|side2)" { type nutkWallFunction; Cmu 0.09; kappa 0.41; E 9.8; value $internalField; } inlet { type calculated; value $internalField; } outlet { type calculated; value $internalField; } } P: dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { outlet { type fixedValue; value $internalField; } inlet { type zeroGradient; } top { type zeroGradient; } bottom { type zeroGradient; } side { type zeroGradient; } side2 { type zeroGradient; } hull { type zeroGradient; } } U: dimensions [0 1 -1 0 0 0 0]; internalField uniform (10 0 0); boundaryField { inlet { type fixedValue; value $internalField; } outlet { type pressureInletOutletVelocity; value $internalField; } "(hull|top|bottom|side|side2)" { type fixedValue; value uniform (0 0 0); } } Thanks for your help |
Display Modes | |
SimpleFoam bounded k and epsilon always diverging | Deagle | OpenFOAM Running, Solving & CFD | 2 | October 20, 2017 12:33 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
k and epsilon diverging in MRFSimpleFOAM | shyam | OpenFOAM Running, Solving & CFD | 1 | April 8, 2013 08:03 |
Problem with SimpleFoam for a solution around an OneraM6 wing | gara1988 | OpenFOAM Running, Solving & CFD | 3 | November 13, 2012 05:47 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 20:21 |
