How can i ramp function for inlet
Like Tree1Likes
  • 1 Post By Tobermory
Old   December 24, 2024, 18:57
Default How can i ramp function for inlet
kendinemühendis is on a distinguished road
How can i make ramp function for inlet? File etc.
kendinemühendis is offline   Reply With Quote
Old   December 26, 2024, 13:50
Tobermory will become famous soon enough
Try something like uniformFixedValue, which allows a tabular input. If that's not what you are after, then you'll need to give us some more details on what you are trying to achieve ...
kendinemühendis likes this.
Tobermory is offline   Reply With Quote
Old   December 27, 2024, 12:38
I want to create a speed value that varies with time.
For example;
time = 0 sec -> U (10 0 10)
time = 1 sec -> U ( 200 0 200 )
U speed will increase as a ramp function within 1 second. I'm drawing a graph as an example.
[IMG] https://resimlink.com/XmHvws13D [/IMG]
Old   December 28, 2024, 08:24
Try:
inlet {
    type                 uniformFixedValue;
    uniformValue    table
                              (0   (10 0 10))
                              (1   (200 0 200))
where "inlet" is the boundary patch name.
Old   December 28, 2024, 09:06
Ata
foldandfly is on a distinguished road
Alternatively, you can use a coded function within the U file:
inlet
        type            codedFixedValue;
        value           uniform (10 0 10);
        redirectType myFunction; // This specifies a name for the coded boundary condition
        code
            const scalar t = this->db().time().value();    // Current time
            const scalar rampDuration = 1.0;   // Duration for ramping (seconds)
            const scalar amplitude = 190;      // Amplitude of ramp function
            const scalar uInitial = 10;      // Velocity at t=0
            scalar ramp = min(t / rampDuration, 1.0); // Gradual ramp
            vector U_inlet = (uInitial + (ramp* amplitude)) * vector(1, 0, 1);
            operator==(U_inlet); // Apply velocity
foldandfly is offline   Reply With Quote
Old   December 28, 2024, 11:54
Thank you! This worked but in the U file "internalField uniform (485.79 0 176.81); " I am having problems with this part. When I write "internalField uniform (450 0 150);" the analysis is solved, but when I write (485.79 0 176.81) it is not solved. What do you think could be the reason? Thank you very much.
Originally Posted by Tobermory View Post
Try:
inlet {
    uniformValue    table
                              (0   (10 0 10))
                              (1   (200 0 200))
Old   December 28, 2024, 11:56
Thank you! I will try
inlet
        code
function, openfoam, ramp
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
