[Sponsors] | |||||
Sea
Rep Power: 4 ![]() |
Hi all,
I am wondering the best workflow in setting initial alpha.water for complex geometries. I have an .stl that represents the water volume (refer attached), and have exported it from blender. This is saved within constant/triSurface directory. I have completed Surface checks with no errors; but cannot get my fields to work. Any ideas as to where I am going wrong or alternate approaches to this issue? My setFieldsDict /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 // Default value for air ); regions ( searchableSurfaceCell { type searchableSurfaceToCell surface "constant/triSurface/waterEx.stl"; inside true; fieldValues ( volScalarFieldValue alpha.water 1 ); } ); // ************************************************** ******************************** // I have tried many sub-variations of this dict file with no success. The error messages have been reasonably consistent with the following: Error Message // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading setFieldsDict Setting volume field default values - set internal values of volScalarField: alpha.water = 0 Setting field region values --> FOAM FATAL IO ERROR: (openfoam-2406) Unknown topoSetSource type searchableSurfaceCell |
Rep Power: 19 ![]() |
I've not used this type of topoSet before, but I think your syntax is wrong. You have named the topoSet block with your own name "searchableSurfaceCell", which is not a recognised type of topoSetSource (that's what the error message is telling you).
You should have named it with the type of topoSetSource that the block contains ... i.e. searchableSurfaceToCell. Check your parameters inside the block as well (ie type should be cellSet, I imagine) - if there's anythging wrong, it will tell you which parameter is missing or is badly formed. Hope that helps - good luck. |
Sea
I have been working through this... after quite a while away from my computer.
My setFieldsDict is currently: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( searchableSurfaceToCell { type triSurfaceMesh; // Correct keyword for surface type surface "waterLevelRegion.stl"; // Correct keyword for surface path includeInside true; // Correct keyword for including cells inside the surface fieldValues ( volScalarFieldValue alpha.water 1 // Set alpha.water = 1 inside the surface ); } ); // ************************************************** *********************** // When I run setFields, I get the following error: Reading setFieldsDict Setting volume field default values - set internal values of volScalarField: alpha.water = 0 Setting field region values --> FOAM FATAL IO ERROR: (openfoam-2406) Unknown searchableSurface type waterLevelRegion.stl Valid searchableSurface types : 24 ( box closedTriSurfaceMesh collection cone cylinder disk extrudedCircle plane plate rotatedBox searchableBox searchableCone searchableCylinder searchableDisk searchableExtrudedCircle searchablePlane searchablePlate searchableRotatedBox searchableSphere searchableSurfaceCollection searchableSurfaceWithGaps sphere subTriSurfaceMesh triSurfaceMesh ) file: searchableSurfaceToCell at line 26 to 32. From static Foam::autoPtr<Foam::searchableSurface> Foam::searchableSurface::New(const Foam::word&, const Foam::IOobject&, const Foam::dictionary&) in file searchableSurfaces/searchableSurface/searchableSurface.C at line 53. FOAM exiting Any ideas on where I am going wrong? |
Sea
As the title says - I needed to run topoSet ahead of setFields. I was getting quite confused between the two when reading other forums across the net.
These are the dictionaries that worked for me: topoSetDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2406 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; arch "LSB;label=32;scalar=64"; class dictionary; location "system"; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name myCellSet; type cellSet; action new; source searchableSurfaceToCell; sourceInfo { surfaceType triSurfaceMesh; // Use triSurfaceMesh for STL files surfaceName water.stl; // Name of the STL file (without .stl extension) mode inside; // Select cells inside the STL geometry } } ); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // setFields dict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object setFieldsDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // defaultFieldValues ( volScalarFieldValue alpha.water 0 ); regions ( searchableSurfaceToCell { surfaceType triSurfaceMesh; // Correct keyword for surface type surfaceName water.stl; //name of surface mode inside; // Correct keyword for including cells inside the surface fieldValues ( volScalarFieldValue alpha.water 1 // Set alpha.water = 1 inside the surface ); } ); // ************************************************** *********************** // I hope this helps someone else at a later stage! |
| Tags |
| blender, setfieldsdict, stl |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 18:45 |
| Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 15:05 |
| pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
| Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
| SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 05:13 |
