Is lift force included by default in mppiccloud?
Old   January 14, 2025, 15:29
Default Is lift force included by default in mppiccloud?
Is Av
IsAv is on a distinguished road
Hello, this must be something very simple but I am lost reading the api description, the question is, is the LiftForce included by default in the particleForces for mppiccloud? I am using of12. I checked the tutorials and all of them include at the most drag and gravity. Thanks a lot.
IsAv is offline   Reply With Quote
Old   January 15, 2025, 15:36
Is Av
Ok there is no default lift force, I followed some other posts, and arrived to these dictionaries modifications in cloudProperties:
interpolationSchemes
        rho.air         cell;
        U.air           cellPointWallModified;
        mu.air          cell;
        alpha.air       cell;
        curlUcDt        cell; //<- this
and
    particleForces
        ErgunWenYuDrag
            alphac alpha.air;
         gravity;
       //this ->
         SaffmanMeiLiftForce
            U    U.air;
to add the SaffmanMeiLiftForce. This runs as longer as there are no particles in the domain, as soon as particles enter, it crushes with the error:
--> FOAM FATAL ERROR:
Carrier phase curlUc interpolation object not set
I thought I was setting the interpolation object by giving the interpolation scheme of curlUcDt with the code above but it seems not. Does anybody know how I should set the object?
Thanks a lot
Old   January 15, 2025, 16:36
Utkan Caliskan
dscian is on a distinguished road
You probably need to define curlUc instead of curlUcDt in interpolationSchemes.
dscian is offline   Reply With Quote
Old   January 15, 2025, 16:47
Is Av
I have tried that in several ways I still get the same fatal error
Old   January 16, 2025, 09:46
Is Av
Ok I am going back may be, there is a LiftForce that calculates (from LiftForce.C):
     forceSuSp value(Zero, 0.0);
     const vector curlUc =
         curlUcInterp().interpolate
              p.coordinates(),
              p.currentTetIndices(td.mesh)
 scalar Cl = this->Cl(p, td, curlUc, Re, muc);
value.Su() = mass/p.rho()*td.rhoc()*Cl*((td.Uc() - p.U())^curlUc)
to which the TomoyamaLift and SaffmanMeiLift contribute, I am prone to think that LiftForce is there by default since it is not offered as an option by ParticleForces but still not sure. I don't what Cl is so I can not confirm, it is defined with value zero in LiftForce.C:
 Foam::scalar Foam::LiftForce<CloudType>::LiftForce::Cl
      const typename CloudType::parcelType& p,
      const typename CloudType::parcelType::trackingData& td,
      const vector& curlUc,
      const scalar Re,
      const scalar muc
  ) const
      // dummy
      return 0.0;
So the LiftForce is zero? How could I confirm that the lift is there?
Old   April 3, 2025, 12:24
Is Av
For the record, it works with collidingCloud, that's enough for me.
increase the lift force for wind turbine blade dipaksutradhar OpenFOAM Running, Solving & CFD 0 January 28, 2015 16:14
Saffman/ Lift Force in Pipe Ruonin Main CFD Forum 0 August 9, 2013 11:34
The lift force coefficient in bubbly flow Kai Yan Main CFD Forum 1 November 4, 2008 14:54
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 08:07
Saffman Lift Force CFD MAN Main CFD Forum 0 November 26, 2002 19:26
