Joseph
Rep Power: 2 ![]() |
Sorry for the long post, but I need help troubleshooting a CFD simulation. I’m trying to simulate airflow in a classroom with students and tables. The classroom has: 3 inlets (vents on the roof), 3 outlets (also vents), 1 door, and 3 windows (considered as "walls" since they are closed). The room dimensions are 3 x 5 x 8 meters. To avoid errors with ideasFoam, I modeled the humans as cylinders with a mouth. The cylinder bases are linked to the floor, and the tables are attached to the walls. When I created the mesh, the cylinder bases became part of the floor, and one face of each table was linked to the wall. This setup allowed ideasFoam to function without errors. I refined the mesh multiple times, and checkMesh reports no issues. Next, I used createBaffles to add face zones to the boundary file, as everything inside the box was initially added to the faceZones file, not boundary. Once the boundaries were correctly updated, I defined: 3 tables and 4 humans (excluding the mouth) as walls. Inlets, outlets, and mouths as patches. (This is a simplified test setup. Once it works, I plan to include all students and tables.) After preparing everything, I ran simpleFoam with the setup. To ensure stability, I: Reduced the time step (deltaT), Adjusted relaxation factors, and Tightened solver tolerances (resTol). Unfortunately, the simulation crashed immediately. When I changed the solver for p (pressure) to PCG, the simulation ran. It converged smoothly with a small time step (deltaT = 0.001) until 1.5 seconds. However, after this point, the bounding k starts to increase steadily, reaching unrealistic values (e.g., max: 9.38163e+07). Do you have any insights into what I might be doing wrong? Here are the files I used: boundary U p k epsilon nut fvSolution fvSchemes controdict Thank you in advance for your help! /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Website: https://openfoam.org | | \\ / A nd | Version: 12 | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; location "0"; object nut; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { floor { type nutkWallFunction; value uniform 0; } walls { type nutkWallFunction; value uniform 0; } ceiling { type nutkWallFunction; value uniform 0; } inlet_door { type calculated; value uniform 0; } windows { type zeroGradient; } inlets { type calculated; value uniform 0; } outlets { type zeroGradient; } humans_master { type nutkWallFunction; value uniform 0; } humans_slave { type nutkWallFunction; value uniform 0; } mouths_master { type calculated; value uniform 0; } mouths_slave { type calculated; value uniform 0; } tables_master { type nutkWallFunction; value uniform 0; } tables_slave { type nutkWallFunction; value uniform 0; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Website: https://openfoam.org | | \\ / A nd | Version: 12 | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; location "0"; object epsilon; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -3 0 0 0 0]; internalField uniform 0.331; boundaryField { floor { type epsilonWallFunction; value uniform 0.0; } walls { type epsilonWallFunction; value uniform 0.0; } ceiling { type epsilonWallFunction; value uniform 0.0; } inlet_door { type zeroGradient; } windows { type zeroGradient; } inlets { type fixedValue; value uniform 0.331; } outlets { type zeroGradient; } humans_master { type epsilonWallFunction; value uniform 0.0; } humans_slave { type epsilonWallFunction; value uniform 0.0; } mouths_master { type zeroGradient; } mouths_slave { type zeroGradient; } tables_master { type epsilonWallFunction; value uniform 0.0; } tables_slave { type epsilonWallFunction; value uniform 0.0; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 12 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; location "0"; object k; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.0258; boundaryField { floor { type kqRWallFunction; value uniform 0.0; } walls { type kqRWallFunction; value uniform 0.0; } ceiling { type kqRWallFunction; value uniform 0.0; } inlet_door { type zeroGradient; } windows { type zeroGradient; } inlets { type fixedValue; value uniform 0.0258; } outlets { type zeroGradient; } humans_master { type kqRWallFunction; value uniform 0.0; } humans_slave { type kqRWallFunction; value uniform 0.0; } mouths_master { type zeroGradient; } mouths_slave { type zeroGradient; } tables_master { type kqRWallFunction; value uniform 0.0; } tables_slave { type kqRWallFunction; value uniform 0.0; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 12 | | \ / A nd | Web: www.OpenFOAM.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { floor { type noSlip; } walls { type noSlip; } ceiling { type noSlip; } inlet_door { type zeroGradient; } windows { type zeroGradient; } inlets { type fixedValue; value uniform (0 0 0.35); } outlets { type fixedValue; value uniform (0 0 -0.35); } humans_master { type noSlip; } humans_slave { type noSlip; } mouths_master { type zeroGradient; } mouths_slave { type zeroGradient; } tables_master { type noSlip; } tables_slave { type noSlip; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 12 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { floor { type zeroGradient; } walls { type zeroGradient; } ceiling { type zeroGradient; } inlet_door { type fixedValue; // Pressure reference point value uniform 0; } windows { type zeroGradient; } inlets { type zeroGradient; } outlets { type zeroGradient; } humans_master { type zeroGradient; } humans_slave { type zeroGradient; } mouths_master { type zeroGradient; } mouths_slave { type zeroGradient; } tables_master { type zeroGradient; } tables_slave { type zeroGradient; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 12 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0.01; } pFinal { $p; relTol 0; } "(U|k|epsilon)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-5; relTol 0.01; } "(U|k|epsilon)Final" { $U; relTol 0; } } relaxationFactors { fields { p 0.2; } equations { U 0.3; k 0.2; epsilon 0.2; } } PIMPLE { nNonOrthogonalCorrectors 2; nCorrectors 2; residualControl { p 1e-4; U 1e-5; "(k|epsilon)" 1e-5; } } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 12 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************** *********************** // /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 12 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; solver incompressibleFluid; startFrom latestTime; startTime 0; stopAt endTime; endTime 3; deltaT 0.0005; writeControl adjustableRunTime; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; maxCo 5; debug 1; // ************************************************** *********************** // Example of the solution after 3s : Time = 3s smoothSolver: Solving for Ux, Initial residual = 0.00371234, Final residual = 6.68207e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.00396574, Final residual = 1.20463e-05, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.00397317, Final residual = 1.27557e-05, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.000101223, Final residual = 9.75821e-06, No Iterations 35 DICPCG: Solving for p, Initial residual = 3.88401e-05, Final residual = 9.83166e-06, No Iterations 21 DICPCG: Solving for p, Initial residual = 1.7923e-05, Final residual = 9.83142e-06, No Iterations 17 time step continuity errors : sum local = 3.33501e-05, global = 2.51784e-05 DICPCG: Solving for p, Initial residual = 8.00657e-05, Final residual = 9.98959e-06, No Iterations 35 DICPCG: Solving for p, Initial residual = 3.17717e-05, Final residual = 9.49924e-06, No Iterations 21 DICPCG: Solving for p, Initial residual = 1.54928e-05, Final residual = 9.994e-06, No Iterations 1 time step continuity errors : sum local = 3.37548e-05, global = 2.51818e-05, cumulative = 0.00310968 smoothSolver: Solving for epsilon, Initial residual = 0.00443172, Final residual = 8.7404e-07, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.00427727, Final residual = 2.12083e-06, No Iterations 2 bounding k, min: 1.82005e-16 max: 9.38163e+07 average: 62990.6 ExecutionTime = 8353.48 s ClockTime = 8355 s |
indoor air, k epsilon, openfaom |
Display Modes | |
Floating point exception when using simpleFoam for OpenFOAM '3 weeks' series | jrr75166 | OpenFOAM Running, Solving & CFD | 0 | August 6, 2024 09:58 |
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial | mörli | OpenFOAM Running, Solving & CFD | 0 | April 9, 2019 11:50 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
simpleFoam crashes (CFDSupport port of OpenFOAM for Windows) | mqsim | OpenFOAM Running, Solving & CFD | 5 | June 30, 2016 02:31 |
Same SimpleFOAM Case converges with openFOAM 2.1 but diverges with openFOAM 2.0.1 | alsdia | OpenFOAM Running, Solving & CFD | 3 | October 22, 2012 11:25 |
