Openfoam different dimension error for hypersonic plane
Old   January 26, 2025, 21:17
Question Openfoam different dimension error for hypersonic plane
Bábel Edvárd István
HyperSonic1 is on a distinguished road
Hi, I am very new to using any CFD; in fact, I am a highschooler. I am designing a plane that goes Mach 17, has 2 nuclear reactors for thrust, etc. My problem is that openFOAM gives me an error (attached picture).
my files if somebody wants to look at them:
https://files.fm/u/tjhckkah3z
I made some .sh files since I am working in Ubuntu to make my life easier.
I use Rhopimplefoam with Openfoam11. (with turbulance) If you need more information, just message me or write it here. Thanks in advance, you wonderful people!
HyperSonic1 is offline   Reply With Quote
Old   January 28, 2025, 07:45
Alczem is on a distinguished road
Hey!
Mach 17? Holy.
The error indicates a dimension problem in your boundary files. My guess is that you used an incompressible case as a starting point. Check the dimensions for nut and alphat (near the header of the files). Change it according to the log message.
Alczem is offline   Reply With Quote
Old   January 30, 2025, 12:27
Bábel Edvárd István
Alphat and nut are the same; I set the dimensions correct from what I can tell, but I provided my project folder so you can check it if I'm wrong.
Old   January 31, 2025, 04:06
Hey!
alphat and nut are indeed the same (I had checked your case before answering) but they are both wrong their dimensions should be set to [1 -1 -1 0 0 0 0 ] according to the error message. See if your case runs after changing it.
Old   January 31, 2025, 22:34
Bábel Edvárd István
I changed both to 1 -1 -1, now it outputs this error, basically the same the dimensions are just flipped
flying wing, hypersonic flow, hypersonics, rhopimplefoam, turbulance
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 03:19
[Other] mesh spatial dimension in OpenFOAM jr33 OpenFOAM Meshing & Mesh Conversion 4 May 23, 2016 11:59
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
