InterFoam fluid fraction problem close to a blade
Old   January 27, 2025, 03:56
Default InterFoam fluid fraction problem close to a blade
Valentin T
val1560 is on a distinguished road
Hi foamers,
Context: I am currently running 2D simulations with interFoam (v2406), URANS with a k-omega SST turbulence model.
A water jet is impacting a 35-blade runner, which is rotating in the air.
My problem: the fluid fraction in the first cells of my boundary layer is not reaching the expected alpha.water = 1. This happens in regions where the blade is completely surrounded by water and where there should be no air close to the blade.
This implies a pressure gap between the first and the following cells of the layers around the blades. The pressure gap is about 10% of the average pressure around the blades in this region full of water.
The turbine torque is directly related to the pressure field around the blades and I am thus worried that the pressure gap observed may affect the performance prediction.
I have tried several types of meshes and different aspect ratios:
- Ansys meshing triangles (named tri_, aspect ratio of max 60) and tri_thinner_, aspect ratio of max 30);
- Ansys meshing quadrilaterals (named quad_, aspect ratio of max 60);
- And snappyHexMesh with boundary layer (named snappyHexMesh_, aspect ratio of max 30).
with no improvement on this problem. (all checkMesh are good)
If you have any idea that may correct or help understand this problem, I would be interested.
Here are some snapshots (for all meshes, alpha.water=aw, pressure on the top and the bottom of the blade).
Files here: https://filesender.renater.fr/?s=dow...a-aec00f12b131
Thank you.
Valentin
val1560 is offline   Reply With Quote
Old   January 30, 2025, 05:44
VRN
Vinayak Ramachandran
VRN is on a distinguished road
Hello val1560,
May I ask what advection schemes are being used in your simulations? Do you use the default interface-compression method or any interface reconstruction schemes?
VRN is offline   Reply With Quote
Old   January 30, 2025, 06:03
Valentin T
Originally Posted by VRN View Post
Hello val1560,
Here are my fvSchemes and fvSolution files.
thank you for your interest !
| \\ / O peration | Version: v2312 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
solvers
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-4;
relTol 0.01;
minIter 1;
maxIter 200;
p_rghFinal
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
maxIter 50;
pcorr
solver PCG;
preconditioner DIC;
tolerance 1e-04;
relTol 0;
maxIter 200;
pcorrFinal
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
maxIter 50;
"alpha.water.*"
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-8;
relTol 0;
nAlphaCorr 10;
nAlphaSubCycles 1;
cAlpha 0.9;
MULESCorr yes;
nLimiterIter 10;
alphaApplyPrevCorr no;
"(U|k|omega)"
smoother GaussSeidel;
tolerance 1e-6;
relTol 0.1;
nSweeps 1;
maxIter 500 ;
"(U|k|omega)Final"
tolerance 1e-6;
relTol 0;
nSweeps 1;
PIMPLE
nNonOrthogonalCorrectors 2;
nOuterCorrectors 10;
nCorrectors 2;
momentumPredictor no;
correctPhi yes;
moveMeshOuterCorrectors yes;
checkMeshCourantNo yes;
residualControl
p_rgh
tolerance 1e-4;
relTol 0.000001;
relaxationFactors
equations
".*" 1;
| \\ / O peration | Version: v2212 |
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
default CrankNicolson 0.7; //0.9;
gradSchemes
default cellLimited Gauss linear 1 ; //leastSquares 1;
divSchemes
div(rhoPhi,U) Gauss linearUpwind grad(U);
div(phi,alpha) Gauss upwind;
div(phirb,alpha) Gauss upwind;
div(phid1,p_rgh) Gauss upwind;
div(phid2,p_rgh) Gauss upwind;
div(rhoPhi,T) Gauss linearUpwind unlimited;
div(rhoPhi,K) Gauss upwind;
div(phi,k) Gauss upwind;
div(phi,omega) Gauss upwind;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited corrected 0.5;
interpolationSchemes
default linear;
snGradSchemes
default limited corrected 0.5;
fluxRequired
default no;
pcorr ;
p ;
p_rgh ;
alpha.water;
wallDist
method meshWave;
Old   January 31, 2025, 08:24
Valentin T
here are my fvSchemes and fvSolution files.
Thank you for your interest.
Valentin
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSchemes;
ddtSchemes
gradSchemes
divSchemes
div(phi,alpha) Gauss interfaceCompression vanLeer 1; // Gauss vanLeer;
div(phirb,alpha) Gauss linear;
laplacianSchemes
default linear;
snGradSchemes
wallDist
method meshWave;
and
FoamFile
version 2.0;
format ascii;
class dictionary;
object fvSolution;
// SO9__tol4
solvers
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-4;
relTol 0.01;
minIter 1;
maxIter 200;
p_rghFinal
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
maxIter 50;
pcorr
solver PCG;
preconditioner DIC;
tolerance 1e-04;
relTol 0;
maxIter 200;
pcorrFinal
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
maxIter 50;
"alpha.water.*"
tolerance 1e-8;
relTol 0;
nAlphaCorr 10;//5;
nAlphaSubCycles 1;
cAlpha 0.9;//1;
MULESCorr yes;
nLimiterIter 10; //5;
"(U|k|omega)"
tolerance 1e-6;
relTol 0.01;
nSweeps 1;
minIter 1;
maxIter 500 ;
"(U|k|omega)Final"
tolerance 1e-6;
relTol 0;
minIter 1;
nSweeps 1;
PIMPLE
nCorrectors 2;
turbOnFinalIterOnly false;
correctPhi yes;
residualControl
p_rgh
tolerance 1e-4;
relTol 0.000001;
relaxationFactors
equations
".*" 1;
alpha.water, interfoam fluid fraction, interfoam interface, interfoam volume fraction, two-phase flow
What are the best settings for a channel flow simulation? Ashkan Kashani CFX 3 October 13, 2022 21:36
Simulation crashes when turbulence is on (reactingMultiphaseEulerFoam) remidemol OpenFOAM Running, Solving & CFD 3 May 26, 2020 05:47
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
[ICEM] Problem with Y+ elements in 3D blade mesh SlapGas ANSYS Meshing & Geometry 12 September 12, 2013 11:40
Problem in conducting CFD of analysis of wind turbine blade atulpat CFX 16 August 17, 2013 04:09
