March 1, 2025, 22:41
Negative temperature, density, and pressure in buoyantSimpleFoam
Ash
Hello all,
I'm simulating laminar flow past a cuboidal obstruction in a cuboidal domain. The domain has an inlet, outlet, sides, and the bottom is a wall. The cuboidal obstruction is a wall on all sides and is located on the bottom face of the domain. I know the velocity and temprature at the inlet coming into the domain. When I try solving this with buoyantSimpleFoam, the temperature, density, and pressure become negative within 2 iterations and the simulation crashes. (The pressure becomes negative at the face of the obstruction opposite the face facing the inlet). If I remove the cuboidal obstruction and just simulate flow in the domain it works fine. Can someone please help me identify the issue? Thank you!
The p_rgh file is here:
| \\ / O peration | Version: v2412 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 101325;
boundaryField
"domain_.*"
type fixedFluxPressure;
value uniform 101325;
domain_outlet
type fixedValue;
obstruction
Here is U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 4.47);
boundaryField
domain_inlet
type fixedValue;
value $internalField;
domain_outlet
type inletOutlet;
inletValue uniform (0 0 0);
domain_left
type zeroGradient;
domain_right
type zeroGradient;
domain_up
type zeroGradient;
domain_down
type noSlip;
obstruction
type noSlip;
Reason: Clarity
