What solver(s) would you use if you were modeling an entire condenser or evaporator?
Old   March 7, 2025, 23:23
Default What solver(s) would you use if you were modeling an entire condenser or evaporator?
Jim Park
bmb333 is on a distinguished road
Hello everyone,
I have been using OpenFOAM mainly for incompressible solvers, but recently I received a task which involves running a simulation for evaporators and condensers (like the ones that you see in HVAC systems).
I was wondering if you guys had some insights on what existing solvers I should look at as starters.
I see some folks doing simulations of bubble rising and falling, but I am not sure whether that level of detail is what I need.
Essentially in my mind, I would be completely satisfied if I can get total heat exchanging capacity in kW, pressure drops across inlets and outlets, and some vapor quality field (or some kind of mass/volume ratio between gas phase and liquid phase). Also, obviously, the solver needs to include some sort of phase change capabilities based on heat transfer.
Some people in the HVAC heat exchanger modeling businesses use the approach called homogeneous equilibrium model (HEM) where they treat the two phases as one mixture. To this end, they operate with enthalpy for energy conservation instead of temperature as the variables. Maybe this is a good approach, but I am wondering whether it is more common for 1D problems and not generalizable for higher dimensions.
Please let me know if you have suggestions. I appreciate your comments in advance!
bmb333 is offline   Reply With Quote
gas and liquid, heat exchanger, phase change, two-phase
fluid material setting in evaporator modeling mogoko CFX 2 October 23, 2018 12:12
a quesion about the simultaneous simulations in modeling heat trnsfer hubert79 FLUENT 0 July 30, 2014 22:21
Problems modeling vertical axid water turbine- divergence in AMG solvers gambiss FLUENT 1 March 13, 2011 13:05
Solvers with "Deterministic Stress" modeling??? Glenn Main CFD Forum 5 December 22, 2007 10:35
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 14:49
