Message truncated, error stack: MPI_Recv(224).......................: MPI_Recv(buf=0x |
Vivekananda
Rep Power: 9 ![]() |
I am facing a strange error.
I am running my case with 80 processors. Now when I am working with particles and a rotating patch called AMI (arbitary meshing interface), Openfoam wants the AMI to be in a single processor. I did that with toposet utility. Now, when I am trying to run it with parallel with scotch decomposition method , I am getting the following error. Fatal error in MPI_Recv: Message truncated, error stack: MPI_Recv(224).......................: MPI_Recv(buf=0x7fff962cc038, count=8, MPI_BYTE, src=26, tag=1, MPI_COMM_WORLD, sta$ MPIDI_CH3U_Request_unpack_uebuf(618): Message truncated; 24 bytes received but buffer size is 8 Strangely, when I am reducing the processors to 40 and changed the decomposition method to simple, it worked. But again, with 40 proc and scotch or hierarchical method, it throws the same error. In summary, Processor Decomposition Error 80 scotch yes 80 simple yes 40 scotch/hierarchical yes 40 simple NO I think the issue might be with MPI. I checked the following link Message truncated, error stack: MPIDI_CH3U_Receive_data_found Here, the issue was solved by changing the comms to nonBlocking in the /apps/material/Openfoam/el7/../.../etc/controDict. I also checked it and found that it's saved as nonBlocking. Can anyone help? |
ami patches, mpi errors, parallel, particle cloud |
Display Modes | |
Message truncated, error stack: MPIDI_CH3U_Receive_data_found | nandiganavishal | OpenFOAM Running, Solving & CFD | 21 | November 19, 2021 01:20 |
ERROR: unable to find library | HJH | CFX | 6 | February 26, 2019 06:52 |
single directional message transmit in parallel model | su_junwei | OpenFOAM Programming & Development | 1 | December 17, 2009 07:00 |
Error message in CFX-10 | CFDworker | CFX | 2 | October 12, 2007 07:23 |
MPI Message truncated | josef | OpenFOAM Running, Solving & CFD | 1 | January 9, 2006 06:29 |
