Like the Hot Room but with Water
Old   March 18, 2025, 10:34
Default Like the Hot Room but with Water
Strumm
Strumm is on a distinguished road
I am looking for a tutorial that considers buoyant effects in a heated WATER tank. Most of the buoyant examples use air as the working fluid, and my attempts to switch to water properties fail miserably. Thanks!
Strumm is offline   Reply With Quote
Old   March 28, 2025, 06:28
Lightbulb
Thiago Parente Lima
thiagopl is on a distinguished road
Hi Strumm,
This type of problem is usually caused by typing errors. Also, think about your problem, when you change the fluid, you may also be changing the laminar<->turbulent flow regime, which can cause a crash.
Also, in situations like this, you have to be more precise: describe your problem and the error messages carefully.
Field of interest: heat transer. OpenFOAM Foundation's distribution user.
thiagopl is offline   Reply With Quote
buoyant, water
Simulation of Water jacket cooled Heat exchanger for hot oil soumitra2102 Fluent Multiphase 0 August 13, 2018 19:35
Need help to Simulate Phase change of Water liquid after mixing with Hot Air Stream diineshns FLUENT 0 March 17, 2018 06:14
I want to model injection of hot water in cold water dilution ahmed_ashmawy FLUENT 1 December 20, 2017 03:40
Evaporation of thin water film Stephen Waite CFX 6 July 3, 2014 22:14
How to model a copper bar pulling out from hot water onlyacan FLUENT 0 October 20, 2010 07:26
