[Sponsors] | |||||
Changing Solver leads to Negative Temperature |
Rep Power: 0 ![]() |
Hello Everyone,
I am trying to simulate a rectangular rocket nozzle and the subsequent discharge to the atmosphere (1atm). I am using K-omega SST turbulence model to run a transient simulation. I am simulating 1/4 of the geometry, with one symmetry at the bottom and at the side. My issue arise when I switch from SonicFoam to rhoCentralFoam to make sure I capture the shocks if any. The simulation always starts correctly, but after 10-30 timesteps (dt = 1e-9s to keep Co<0.2) I get this meessage: Time = 8e-07 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0 diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 2.08375e-05, Final residual = 1.16963e-08, No Iterations 3 smoothSolver: Solving for Uy, Initial residual = 6.43467e-08, Final residual = 7.41012e-13, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 3.1202e-06, Final residual = 4.32488e-10, No Iterations 3 diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for e, Initial residual = 9.57685e-06, Final residual = 9.57685e-06, No Iterations 0 --> FOAM FATAL ERROR: (openfoam-2406 patch=241212) Negative initial temperature T0: -0.666552 From Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam: erfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam: er fectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]in file ./src/thermophysicalModels/specie/lnInclude/thermoI.H at line 57. FOAM aborting [stack trace] ============= #1 Foam::error::simpleExit(int, bool) in /usr/lib/openfoam/openfoam2406/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so #2 ? in /usr/lib/openfoam/openfoam2406/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so #3 ? in /usr/lib/openfoam/openfoam2406/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so #4 ? in /usr/lib/openfoam/openfoam2406/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so #5 ? in /usr/lib/openfoam/openfoam2406/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam #6 ? in /lib/x86_64-linux-gnu/libc.so.6 #7 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #8 ? in /usr/lib/openfoam/openfoam2406/platforms/linux64GccDPInt32Opt/bin/rhoCentralFoam ============= Aborted (core dumped) the line that concerns me the most is : --> FOAM FATAL ERROR: (openfoam-2406 patch=241212) Negative initial temperature T0: -0.666552 As I said, this error does not happen If I use sonicFoam. My divSchemes is: divSchemes { default none; div(phi,omega) Gauss limitedLinear 1; //SST div(phi,k) Gauss upwind; div(tauMC) Gauss linear; div(phi,U) Gauss limitedLinearV 1; div(phi,e) Gauss limitedLinear 1; div(phid,p) Gauss limitedLinear 1; div(phi,K) Gauss limitedLinear 1; div(phiv,p) Gauss limitedLinear 1; div(phi,epsilon) Gauss upwind; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } Although I already tried many combinations. I believe my mesh is okay as it passed the checkMesh and Simular problem appears if I use only a blockMesh to generate a simple mesh, instead of my complex nozzle. Has Anyone has the same problem? |
| Tags |
| convergence failure, rhocentrafoam, sonicfoam convergence, temperature |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| compressibleInterFoam: Negative temperature or printStack | rpachaly | OpenFOAM Running, Solving & CFD | 3 | June 22, 2022 03:03 |
| Changing Frozenflowfield in chtMultiRegionFoam Solver during simulation | meshingpumpkins | OpenFOAM Programming & Development | 4 | February 18, 2019 19:43 |
| [ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
| Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
| [blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
