Giorgio
Rep Power: 4 ![]() |
Dear all,
I am trying to run a simple multi-region case in parallel. The case has conduction/convection/radiation. It runs ok in serial. I am on OpenFOAM 23.12. When I run in parallel, I get the following error: HTML Code:
The number of faces on either side of the coupled patch 0 are not the same I am attaching the case if someone wants to take a look. Cheers |
Giorgio
I think the problem comes from the fact that the domain decomposition is not able to preserve the face zones. If I use less processors, it works fine.
Now it seems to me that the routine domainDecomposition should at least complain if it's not able to comply with the constraints imposed, but it doesn't. |
Giorgio
Does anyone have an idea how to force the decomposition to comply with the interfaces constraint? I have a multi-region case with 30 millions of cells and I can't even distribute it in 8 processors.
Seems kind of a harsh limitation. |
chtmultiregionfoam, parallel |
Display Modes | |
Help with PIMPLE algorithm in chtMultiregionFoam | Chris T | OpenFOAM Running, Solving & CFD | 0 | August 30, 2022 08:49 |
Problem for parallel running chtMultiregionFoam | Giancarlo_IngChimico | OpenFOAM Programming & Development | 4 | December 21, 2016 03:26 |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 13:13 |
simpleFoam in parallel issue | plucas | OpenFOAM Running, Solving & CFD | 3 | July 17, 2013 11:30 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
