periodic BC & pressure gradient in a 2D two-phase turbulent pipe flow |
Andrew H. Li
Rep Power: 2 ![]() |
Hi Foamers,
I just got a question regarding imposing the periodic BC and the pressure gradient implementation. My flow is as the figure attached where the water flows in against the pipe wall and the crude oil comes in from the centre core. I've set three pairs of periodic(cyclic) BCs. Several questions here: 1. I saw the reference that there's a way to mimic the pressure gradient and drive the flow by specifying the mass flow rate, can anyone show me the syntax of specifying a mass flow rate? I saw the syntax of the meanVelocityForce : pressureGradient { type meanVelocityForce; active true; selectionMode all; meanVelocityForceCoeffs { selectionMode all; // Apply force to all cells fields (U); // Name of velocity field Ubar (0.5 0 0); // Desired mean velocity relaxation 1; // Optional relaxation factor } } Or the syntax of momentumSource(my guess is they are identical): //momentumSource //{ // type meanVelocityForce; // selectionMode all; // fields (U); // Ubar (0.5 0 0); //} 2. if the two phases of flow in my case have different flow rates (this can be easily done if to work with velocity inlets), is it possible to impose different mass flow rate for different phases, if yes and how? I appreciate your help! Thanks! |
Display Modes | |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 13:14 |
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 17:31 |
Periodic Pipe Flow LES | dvolkind | CFX | 8 | March 21, 2020 05:30 |
2 phase flow in a pipe, reference pressure | wissal | CFX | 2 | April 13, 2017 07:08 |
pressure gradient of a 2D periodic flow problem | Honey | FLUENT | 1 | October 17, 2012 06:06 |
