Configuration of the speciesTable file for absorptinEmissionModel greyMean |
Thiago Parente Lima
Rep Power: 15 ![]() |
Hi all,
I'm running a case with a non-reacting gas mixture. The gases are considered participating media, and I'm using the P1 radiation model with the greyMean absorption model to compute the absorption coefficients. My radiationProperties file is configured as follows: Code:
radiation on; radiationModel P1; solverFreq 1; absorptionEmissionModel greyMean; greyMeanCoeffs { lookUpTableFileName "speciesTable"; EhrrCoeff 0.0; CO2 { Tcommon 200; // Common Temp invTemp true; // Is the polynomial using inverse temperature. Tlow 200; // Low Temp Thigh 2500; // High Temp loTcoeffs // coefss for T < Tcommon ( 0 0 0 0 0 0 ); hiTcoeffs // coefss for T > Tcommon ( 18.741 -121.31e3 273.5e6 -194.05e9 56.31e12 -5.8169e15 ); } H2O { Tcommon 200; invTemp true; Tlow 200; Thigh 2500; loTcoeffs ( 0 0 0 0 0 0 ); hiTcoeffs ( -0.23093 -1.12390e3 9.4153e6 -2.99885e9 0.51382e12 -1.868e10 ); } scatterModel none; sootModel none; According to the foamInfo greyMean documentation, "All the species in the dictionary need either to be in the look-up table or be solved." Since this is a non-reacting case, I am not solving for any species fields. Therefore, I want to define them in the speciesTable instead. My question is: What is the required structure and format of the speciesTable file? P.S.: I can successfully run the case by defining species properties and molar fractions in the physicalProperties file and 0/ folder, respectivley. However, my goal is to include soot absorption in the calculation without having to consider soot into the thermodynamics of the system (properties, mass fraction...).
Field of interest: heat transer. OpenFOAM Foundation's distribution user. Last edited by thiagopl; June 2, 2025 at 14:50. Reason: Peace of repeated text removed. |
anonymous.
Rep Power: 7 ![]() |
Hi thiagopl
You can find more information in this file: OpenFOAM-10/src/radiationModels/absorptionEmissionModels/interpolationLookUpTable.H I think it may have the following form: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 10 | | \\ / A nd | Web: http://www.openfoam.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "constant"; object radiationProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // fileName "Soot"; fields ( { N 2; max 1000; min 300; name Temperature; } ); output ( {name Temperature;} {name largeSoot;} {name smallSoot;} ); values ( 3(300 500 1000) // temperature 3(0.3 0.2 0.1 ) //for large soot 3(0.1 0.2 0.3 ) //for small soot ); // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // When interpolation is performed, the table will calculate the value of large soot and small soot based on the temperature |
Display Modes | |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 12:41 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
