heatSource scenarios
Old   June 12, 2025, 18:18
Default heatSource scenarios
Suhan Umur Okuducu
suoCFD is on a distinguished road
I have edited the question I asked here because it could be misunderstood.
I would like to ask whether there is any difference between the following two scenarios in terms of value to be defined for heatSource in OpenFOAM:
1. A scenario where the fluid does not contain a heat source (like the heatedDuct tutorial)
2. A scenario where the fluid does contain a heat source (like the coolingSphere tutorial)
I also have another question:
In the coolingSphere tutorial, which uses chtMultiRegionFoam, how can we model a case where there is no airflow (i.e., no inlet or outlet)?
Can the fluid boundary conditions be taken directly from the hotRoom tutorial in this case? Or how should such a case be modeled in general?
I once asked for help on the forums by sharing a case file to get advice on the boundary conditions for this kind of setup, but I didn’t get a response at the time. I would really appreciate any help you can provide on this matter.
suoCFD is offline   Reply With Quote
Old   July 10, 2025, 08:19
John Mary
JohnMary is on a distinguished road
Greetings,
Can you please share the case you want to modify and say exactly what you want to add or remove ?
Regards,
JohnMary is offline   Reply With Quote
Is the heatSource dependent on the total number of cells of all computational domain? suoCFD OpenFOAM Running, Solving & CFD 5 January 5, 2025 12:37
Eek! nOuterCorrectors eating energy from heatSource? KarenRei OpenFOAM Running, Solving & CFD 10 October 14, 2018 16:55
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 05:07
New workstation for different usage scenarios - CPU and RAM natem Hardware 6 August 7, 2013 02:47
heatsource on cooler -> using buoyantBoussinesqSimpleFoam klio OpenFOAM Running, Solving & CFD 0 April 24, 2012 09:23
