[Sponsors] | |||||
Help: Simple reactingFoam temperature exploding (New user) |
D.C
Rep Power: 2 ![]() |
Hi all,
I am a new user to OpenFOAM and trying to start easy. Ran IcoFoam case for flow around a cylinder (similar to this one) without issue. I am transporting this case to a final setup I want to build towards in reactingFoam. The setup is oriented vertical with open atmospheric boundary conditions on the sides. The inlet field is 700 C air (O2/N2). I'm running openfoam2506, but get similar issue with openfoam12. The issue is that temperature explodes after about 0.8 s. What am I doing wrong? I am guessing boundary conditions? I see residuals as nan in PIMPLE iterations. Any help is appreciated! I get warnings like this - Code:
--> FOAM Warning :
From Foam::scalar Foam::janafThermo<EquationOfState>::limit(Foam::scalar) const [with EquationOfState = Foam::perfectGas<Foam::specie>; Foam::scalar = double]
in file ./src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 120
attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 5000; T = -8.01293e+16
Last edited by DCFireCFD; September 12, 2025 at 14:07. Reason: adding more details |
Rep Power: 0 ![]() |
Hi, D.C. Do you solve this problem? I also met the temperature out of range problem followed by float exception. At the beginning, my simulation only can run within 5 steps (time step:1e-6s), I followed the answers Low-Re Modelling to modified BC and it could let the simulation reach at 9e-5s, then the temperature problem still occurred, through the contours, I think the BC conditions might be the primary barrier.
| Tags |
| flow across a cylinder, reactingfoam |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem installing FOAM2CSR | quarkz | OpenFOAM Programming & Development | 9 | November 7, 2024 12:14 |
| Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
| Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
| reactingFoam - wrong (temperature) profile | megacrout | OpenFOAM | 1 | August 1, 2011 06:11 |
| Simple question to Window XP Fluent user | Aireen | FLUENT | 3 | August 22, 2005 11:36 |
