foamRun iteration not starting - OpenFOAM v13
Old   October 1, 2025, 14:57
Default foamRun iteration not starting - OpenFOAM v13
AlxB is on a distinguished road
I try to run a multiphase unsteady case which includes non Conformal Coupling, similar to the Mixer Vessel Horizontal 2D tutorial, but foamRun cannot start, in serial as in parallel:
here is the log.foamRun in parallel:
Pstream initialised with:
    floatTransfer      : false
    nProcsSimpleSum    : 0
    commsType          : nonBlocking
    polling iterations : 0
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0.1
patchToPatch: Calculating couplings between ...
    source patch nonCouple1 with 1480 faces and ...
    target patch nonCouple2 with 1480 faces
    Source min/average/max coverage = 1/1/1
    Target min/average/max coverage = 1/1/1
    Source average openness/error/depth/angle = 6.67161e-17/9.51971e-14/2.15455e-15/2.67494e-07
    Source max openness/error/depth/angle = 4.10172e-16/2.77556e-11/1.00365e-13/1.47878e-06
    2960 couplings calculated in 0.142547s
fvMeshStitcher: Connecting
    Cell min/average/max openness = 0/1.3165e-17/2.69572e-16
    Cell min/average/max projected volume fraction = 0/5.41624e-15/2.04614e-13
Selecting fvMeshMover motionSolver
Selecting motion solver: solidBody
Selecting solid-body motion function rotatingMotion
Selecting solver incompressibleVoF
Selecting viscosity model Newtonian
No MRF models present
Restarting alpha
Courant Number mean: 7.78143e-20 max: 6.48268e-18
Interface Courant Number mean: 0 max: 0
Selecting turbulence model type RAS
    Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
DICPBiCGStab:  Solving for pcorr, Initial residual = 0.00121499, Final residual = 1.21272e-07, No Iterations 137
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in transient mode with 1 outer corrector
PIMPLE: Operating solver in PISO mode
Starting time loop
End
Finalising parallel run
and here is the controlDict:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  13
     \\/     M anipulation  |
FoamFile
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
solver     		incompressibleVoF; //interFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
// stopAt          writeNow;
endTime         0.1;//20;
deltaT          1e-7;
writeControl    adjustableRunTime;
writeInterval   0.01;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           0.5;
maxAlphaCo      0.25;
maxDeltaT       1e-3;
functions
	#include "FOwriteFields"
	// #include "FOsampleU"
	// #include "FOsampleP_rgh"
	// #include "FOsampleAlphaPhase1"
	// #include "FOsampleUMean"
	// #include "FOsampleUPrime2Mean"
what could be the reason for that ? where to look at ?
many thanks in advance for the help
AlxB is offline   Reply With Quote
Old   October 2, 2025, 03:11
Lukas
Pappelau is on a distinguished road
This one is easy you start from LATESTTime which is 0.1 and stop at 0.1 so what did you expect ? if you want to start from 0 either delete the old solution or write startTime instead of latestTime.
Pappelau is offline   Reply With Quote
Old   October 5, 2025, 10:36
thank you
the old solution was not deleted. shame on me
foamrun, openfoam v13
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 20:20
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
