how to manage createNonConformalCouples Maximum openness Fatal Error in OpenFOAM v13
Old   October 5, 2025, 10:43
Default how to manage createNonConformalCouples Maximum openness Fatal Error in OpenFOAM v13
AlxB is on a distinguished road
Dear Foamers,
depending on the mesh, I often gets this createNonConformalCouples Maximum openness Fatal Error despite the mesh improves: how to get rid of it? is the maximum openness tolerance manageable in a dictionary ?
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  13
     \\/     M anipulation  |
Build  : 13-cde978a97c93
Exec   : createNonConformalCouples nonCouple1 nonCouple2
Date   : Oct 05 2025
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Adding nonConformalCyclic interfaces between patches:
    (nonCouple1 nonCouple2)
In regions:
    (region0 region0)
Named:
    (nonConformalCyclic_on_nonCouple1 nonConformalCyclic_on_nonCouple2)
With transform:
    transformType   none;
patchToPatch: Calculating couplings between ...
    source patch nonCouple1 with 5935 faces and ...
    target patch nonCouple2 with 5935 faces
    Source min/average/max coverage = 1/1/1
    Target min/average/max coverage = 1/1/1
    Source average openness/error/depth/angle = 6.6739792e-17/3.5896548e-13/6.6417338e-15/2.6364017e-07
    Source max openness/error/depth/angle = 4.4006583e-16/1.175864e-10/4.7760787e-13/1.7075473e-06
    11870 couplings calculated in 2.118642s
fvMeshStitcher: Connecting
    Cell min/average/max openness = 0/2.2793813e-10/1.946623e-06
--> FOAM FATAL ERROR:
Maximum openness of 1.946623e-06 is not tolerable
    From function bool Foam::fvMeshStitcher::connectThis(bool, bool, bool)
    in file fvMesh/fvMeshStitchers/fvMeshStitcher/fvMeshStitcher.C at line 1827.
FOAM exiting
thank you in avance for your help
AlxB is offline   Reply With Quote
maximum openness, nonconformalcouples, openfoam v13, quality, tolerance
OpenFOAM 4.0 Released CFDFoundation OpenFOAM Announcements from OpenFOAM Foundation 2 October 6, 2017 06:40
--> FOAM FATAL ERROR: Maximum number of iterations exceeded adambarfi OpenFOAM Running, Solving & CFD 35 April 27, 2016 09:55
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
Maximum parameter values in OpenFOAM vetnav OpenFOAM 1 February 28, 2011 14:28
