[Sponsors] | |||||
Abnormal accumulation of waves occurred in the floatingBody case |
Rhea Ray
Rep Power: 0 ![]() |
Dear Foamers,
I want to build a floating body model in a water tank, modifying the v1906 - overInterDyMFoam - floatingBody case. I changed the original 5 wall boundaries to inlet, outlet, and 3 walls. I added the waveProperties file in constant folder. The wave type is StokesI. The program runs, but the results are confusing. Using waveAlpha as the inlet boundaryField. The result of alpha.water shows the water level line fluctuates up and down in the inlet face, proving that the wave-making is successful. However, the waves seem to accumulate at the frontend and backend (as shown in the figure) and do not propagate forward. ![]() I checked the U results. In the accumulated part, U is very large, but it seems difficult to transmit. I haven't checked the Courant number (I'm still learning how to add new outputs). In the controlDict, I set maxCo = 1; maxAlphaCo = 1; maxDeltaT = 0.01. The minimum mesh size δx is 0.01m (there is little difference between the background and the floating body), deltaT = 0.005, and adjustTimeStep is open. The relevant files are as follows: [alpha.water] Code:
boundaryField
#includeEtc "caseDicts/setConstraintTypes"
oversetPatch
type overset;
inlet
type waveAlpha;
waveDictName waveProperties;
value uniform 0;
outlet
type zeroGradient;
stationaryWalls
type zeroGradient;
atmosphere
type inletOutlet;
inletValue uniform 0;
value uniform 0;
floatingObject
type zeroGradient;
[p_rgh] Code:
boundaryField
oversetPatch
patchType overset;
type overset;
inlet
type fixedFluxPressure;
gradient uniform 0;
value uniform 0;
outlet
gradient uniform 0;
value uniform 0;
stationaryWalls
value uniform 0;
atmosphere
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 1;
value uniform 0;
floatingObject
overset
patchType overset;
boundaryField
oversetPatch
patchType overset;
type zeroGradient;
inlet
type waveVelocity;
value uniform (0 0 0);
outlet
type waveVelocity;
stationaryWalls
type fixedValue;
atmosphere
type pressureInletOutletVelocity;
floatingObject
type movingWallVelocity;
[zoneID] Code:
boundaryField
inlet
type zeroGradient;
outlet
type zeroGradient;
stationaryWalls
type zeroGradient;
atmosphere
type zeroGradient;
floatingObject
type zeroGradient;
oversetPatch
patchType overset;
type zeroGradient;
[waveProperties] Code:
inlet
alpha alpha.water;
waveModel StokesI;
nPaddle 1;
waveHeight 0.1;
waveAngle 90.0;
rampTime 3.0;
activeAbsorption yes;
wavePeriod 0.5;
outlet
alpha alpha.water;
waveModel shallowWaterAbsorption;
nPaddle 1;
[controlDict] Code:
libs ("liboverset.so" "libfvMotionSolvers.so");
application overInterDyMFoam ;
startFrom latestTime;
startTime 0.0;
stopAt endTime;
endTime 4.0;
deltaT 0.005;
writeControl adjustableRunTime;
writeInterval 0.1;
purgeWrite 0;
writeFormat ascii;
writePrecision 12;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 1;
maxAlphaCo 1;
maxDeltaT 0.01;
functions
probes
type probes;
libs ("libsampling.so");
// Name of the directory for probe data
name probes;
// Write at same frequency as fields
writeControl timeStep;
writeInterval 1;
// Fields to be probed
fields (p U);
// Optional: interpolation scheme to use (default is cell)
interpolationScheme cell;
probeLocations
(0.00132 0.0009 0.005)
alphaVol
libs ("libutilityFunctionObjects.so");
type coded;
name alphaVolume;
writeInterval 10;
codeWrite
const volScalarField& alpha =
mesh().lookupObject<volScalarField>("alpha.water");
Info<< "Alpha volume = " << alpha.weightedAverage(mesh().Vsc()) << endl;
1. Reduce the time step; 2. Shorten/lengthen the calculation domain; 3. Changed the wave generation boundary to variableHeightFlowRate, but the result was not satisfactory; 4. Calculated different wave height inputs, ranging from 0.01m to 0.4m; 5. Changed the position of overSetPatch; 6. Change the div(rhoPhi,U) in flie.fvSchemes from "Gauss linear" to "Gauss linearUpwind grad(U)"; The entire case file is attached. Thank you in advance for your help. |
| Tags |
| floating body, openfoam 1906, wave modelling |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Pressure instabilities with interDyMFoam for the floatingObject case | nbadano | OpenFOAM Running, Solving & CFD | 15 | October 15, 2021 07:35 |
| Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
| MRFSimpleFoam wind turbine case diverges | ysh1227 | OpenFOAM Running, Solving & CFD | 2 | May 7, 2015 11:13 |
| Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 07:00 |
| Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
