Error in setup files (libAcoustics)
Old   October 30, 2025, 18:23
Default Error in setup files (libAcoustics)
uditrao04 is on a distinguished road
Hi all, I started exploring the libAcoustics library recently. I am getting an error while executing pimpleFoam (in parallel on 8 cores). The case is the propeller tutorial from $FOAM_TUTORIALS.
My system/controlDict file is as follows:
|  \\    /   O peration     | Version:  v2406                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      controlDict;
application     pimpleFoam;
startFrom       startTime;
startTime       0;
stopAt          endTime;
endTime         0.1;
deltaT          1e-5;
writeControl    adjustable;
writeInterval   0.001;
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes;
maxCo           2;
functions
    acousticFW_H
        type            FfowcsWilliamsHawkings;
	formulationType Farassat1AFormulation;
        libs            ("libAcoustics.so");
	patches ();
        executeControl  timeStep;
        executeInterval 1;
        writeControl    timeStep;
        writeInterval   1;
        c0            343;
	pInf			0;
        pRef            0;
	pName			p;
	rhoName			rho;
	rho				rhoInf;
	rhoInf          1.225;
        interpolationScheme  cell;
        origin              (0 0 0);
        rotation
            type        axes;
            e1          (1 0 0);
            e2          (0 1 0);
	surfaces
		propellerSurface
			type		patch;
			patches		("propeller");
	cleanFreq       100;
        fixedResponseDelay false;
        responseDelay   0.1;
        nonUniformSurfaceMotion false;
        Ufwh    (.0 .0 .0);
        U0      (.0 .0 .0);
        probeFrequency	1;
	timeStart       0;
        timeEnd         1e10;
        observers
            mic1
                type        point;
                position    (0 0.5 0.2);
            mic2
                type        point;
                position    (0 0.5 0);
            mic3
                type        point;
                position    (0 0.5 -0.2);
            mic4
                type        point;
                position    (0 0.7 0);
        calculateSPL     yes;
        SPLRefPressure   2e-5;
        writeFields      yes;
        log              yes;
	writefft		false;
    #includeFunc Q
    #include "forces"
    #include "propellerInfo"
    #include "surfaces"
    #include "AMIWeights"
libs
    "libAcoustics.so"
The error is attached as a file as it is too big to embed.
Error.txt
Thank you! Kindly let me know if any more information is needed to come to a conclusion.
uditrao04 is offline   Reply With Quote
acoustic analysis, acoustics, ffwh model, propeller
[Gmsh] Meshing 3D volume from STL/STEP Files (Gmsh) jgross OpenFOAM Meshing & Mesh Conversion 6 July 15, 2022 06:11
how to use github to backup/track customized OF src/app/case files cfdopenfoam OpenFOAM Programming & Development 0 May 27, 2017 16:33
[snappyHexMesh] snappyHexMesh does not create boundary patches from .stl files bug_or_feature OpenFOAM Meshing & Mesh Conversion 7 August 30, 2016 20:18
[Workbench] Converting mesh files back into geometry files dufferbrady ANSYS Meshing & Geometry 1 April 7, 2016 20:38
attaching trn files hossein_sml CFX 1 August 5, 2015 20:17
